Det finnes ingen tester av denne høyttaleren så det er vanskelig å forstå hva Kudos Titan T88 representerer.
Allikevel, musikalsk, rytmisk, nydelig mellomtone og strekker seg langt i frekvensfløyene.
Dette er de beste høyttalerne jeg har hatt i eie.
De er lettdrevne, jeg driver dem med 80 transistorwatt, men har en god kilde.
Bassen er isobarisk, det vil si 2 elementer som spiller i motfase.
Den siste tiden har de stått helt inntil bakvegg i mitt lytterom (28m2), men fungerer også ut på gulvet. Det kommer an på hva du er ute etter.
Jeg selger ikke for annet enn nedgradering og andre familiære prioriteringer.
Jeg kan vurdere høyttalere i innbytte. Naim, Rega, Neat, Harbeth, Sonus Faber, Spendor, Kudos (Super20)
Alt tilbehør, emballasje og ekstra Chord Sarum jumpere følger med.
Prisen er endelig og kjøper betaler også frakt.
Noen kommentarer hentet fra nett:
-Titans were very impressive in solid sound foundation, developing extremely low infrabass with amazing weight, punch and articulation.
- I immediately took a liking to the Titan's. They were, to quote you, "a complete Grand speaker". They presented a complete full range sound perfectly integrated from bottom to top. The bass allowed for the differentiation of every note and you were able to listen and fully appreciate the musicality of the bass player. Each bass note was easily discernible - not a simplistic boom boom. There was speed and clarity in spades yet the speakers just oozed class, refinement and sophistication in their presentation. They were almost like a finely crafted Swiss watch. Another additional bonus was that one did not need to turn the wick up on the volume to appreciate a full range sound. They were perfectly capable of being listened to late night at lower volumes without losing any of their scale. Finally looks and build quality were simply exemplary. They are slightly deeper and wider than my Allaes and a bit taller. No problem at all with their size.
The Neat XL6`s were falling down on everything - when COMPARED to the Titans.
The sound was not as refined and sophisticated as the Kudos. The bass was not even in the same league falling down on a lack of tunefulness. The Titan's bass sounded like real bass instruments while the Neat's simply went boom - bass "noise" without hearing the actual varying tonalities of the instrument. For this reason the Titans presented a totally seamless integration of full range sound while the Neat's gave a significantly better version of my Allaes - with more bass "tacked on". Not as complete, whole and organic sounding as the Titan's. The Titans immediately let you know they are something special - a finely crafted rich sounding pair of speakers oozing quality and craftsmanship - the attention to detail and quality of materials and construction appearing almost jewel like when compared to the Neats. My Titans will be arriving shortly.
- Starting to listen more intently the level of detail conveyed by these speakers became more and more impressive. These speakers are large beasts and yet worked comfortably in moderate sized listening room. A large range of music just gave more and more detail to familiar tracks. The tonal balance was excellent, the bass was very impressive, deep, tuneful, incredibly well resolved and taught, and seemingly immune from room resonances. Jazz and pop (electric and acoustic) all brought a new level of resolution and insight. The test came on classical, still having the sense of realism the S400's showed on choral work the same track (Paul McCreesh?s Messiah, Hallelujah chorus) as put and the Titans showed their pose and balance, the orchestral detail and control of the timpani was something of revelation.
Titans were truly impressive, headphone like in their presentation and the ease of reproducing across the audio spectrum and speed and control is fantastic.
Teknisk:
Type: 2.5 way Isobaric Bass Reflex
Recommended Amplifier Power: 25W - 300W
Sensitivity: 91dB / @1W / 1m
Nominal Impedance: 8 ohms
Frequency range: 20 Hz - 30kHz
Tweeter: SEAS - Kudos Crescendo K2 29mm fabric dome
Mid bass driver: SEAS - Kudos 220mm Nextel coated paper cone with 39mm voice coil
Bass driver: SEAS - Kudos 220mm double coated hard paper cone with 39mm voice coil (x 2)
Dimensions: 1115mm x 275mm x 370mm (hwd)
Weight:
66kg
Teknisk:
Weight:
66kg
