Vi selger et brukt par Harbeth Compact 7ES-3 m/ stativ tatt i innbytte for kunde. Unde ett år gamle.
The iconic Compact 7ES-3 loudspeaker is now available to pre-order in a stunning Tamo Ash wood veneer, with the additional enhancements of the Harbeths 40th Anniversary range including; the latest WBT-nextgen bind posts, British-made audio grade poly capacitors, and Harbeths 40th Anniversary ultra-pure OFC internal cable. Each speaker will also include the exclusive Harbeth 40th Anniversary front and back badges and the metallic black and gold anniversary grille badge. Each celebratory model will also be packaged in our new Harbeth branded cotton bags.
"The design and engineering of the Compact 7 is so solid and sophisticated... that it sounds absolutely wonderful, retaining its essential neutrality and natural tonal balance..."
'The Absolute Sound' Magazine USA
Whatever you ask of the Compact 7ES-3, it always delivers: perfectly. The clarity is spellbinding and brings the 'magic carpet ride' experience to the listening room in a medium-sized enclosure. The world-class HL Compact 7ES-3 takes the ultra-clean Harbeth-exclusive RADIAL2 cone technology to another performance level. This medium-sized loudspeaker combines natural sound with a flair for reproducing any and every type of music. The Harbeth secret for natural sound is the result of the meticulous attention to detail. Critically important, but hidden, is the crossover for seamless integration of the drive units across a wider horizontal and vertical arc meaning that the Compact 7ES-3 is far less critical of stand height than many speakers of this size.
Specifications
- Transducer system: 2-way reflex 200mm RADIAL2 mid/bass unit, 25mm dome tweeter with HexGrille.
- Freq. response: 46Hz - 20kHz +/-3dB, free space, 1m with grille on with smooth off-axis response.
- Impedance: 6 ohms, easy to drive.
- Sensitivity: 86dB/1W/1m
- Amp. suggestion: Works with a wide range of amplifiers, ideally from 25W/channel.
- Power handling: 150W programme
- Connector: Two 4mm gold-plated binding posts for wires or plugs
- Dimensions (hxwxd): 520 x 272 x 305mm (+12mm for grille and binding posts)
- Space needs: Overall response optimised for use away from walls.
- Stands: To bring ears level with tweeters: typically 15 - 21 inches.
- Weight: 13.2kg each, without packing
- Packing: Single speaker per protective carton
Specifications
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
