Meget pent brukt, demokjøpt fra PM audio, plasten på front display sitter på..
Meget godt fornøyd, mange valgmuligheter så det skal være mulig å finne sitt eget perfekte oppsett
Fjernkontroll
lengde 25,5cm (28,5 cm inkl antenner), bredde 20 cm, høyde inkl "ben" 8,5 cm
Fra brukermanualen
- streaming DAC designed for the contemporary audiophile and featuring a new generation D/A Converter, UPnP-DLNA Streamer, Line Preamplifier and Headphone Amplifier.
- Roon, Airplay, Tidal, MQA, Qobuz, Spotify, Deezer, vTuner
- control the DS-10 with your smartphone or tablet through App
- professional 6.3mm headphones output with two sensitivity levels (High/Low),
1x RCA coaxial PCM asynchronous up to 24bit/192kHz
2x TOS-Link PCM asynchronous up to 24bit/192kHz
1x AES/EBU balanced PCM asynchronous up to 24bit/192kHz
1x USB-B up to DSD512 and PCM up to 32bit/384kHz
1x USB-A port DSD64 and PCM up to 24bit/192kHz, formatted in FAT32/NTFS (32Gb max for pen drives)
Ethernet, Wi-Fi, Bluetooth
Formats
Up to PCM 24/192kHz
- AIFF (.aif, .aiff, .aifc)
- ALAC
- WAV (.wav) packed/unpacked | FLAC
- MP3
- DSD64: DSF, DFF | Apple Lossless
- OGG
- Monkey’s
SUPPORTED MEDIA SERVERS
All UPnP
DLNA
Roon
Kan sendes for kjøpers ansvar og kost
Kan levere i Bergensområdet
Fjernkontroll
Fra brukermanualen
- D/A Converter AKM AK4493 PCM up to 32bit/768kHz and DSD512
- Streamer Network Player PCM and DSD
- Frequency response: 20Hz-20kHz +/-0.1dB
- THD (Total Harmonic Distortion): 0.001% max
- Signal to Noise ratio: 125dB
- Dynamic range: 120dB
- Output impedance RCA/XRL: 50Ω
- DAC: 1 RCA @ 2Vrms, 1 XLR @ 2Vrms
- Preamp:1 RCA, 1 XLR, 1 headphone output with 6.3 mm jack
Formats
Up to PCM 24/192kHz
- ALAC
- MP3
- OGG
- Monkey’s
All UPnP
DLNA
Roon
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
