D
Einstein Audio Final Cut Mk70 OTL Monoblocks (ny pris) Solgt
Effektforsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Pris
Kr 94.500
Kjøpt av
Dave
Annonse beskrivelse
Annonse nummer: 235489
This is the final ultimate version of the amazing Einstein Final Cut OTL.
In perfect condition and used carefully for demo only.
Has been re-valved and serviced.
These mono-block amps are rarely seen for sale as it is so good. Only bettered by the current Einstein Silver Bullet at over €50,000.
It plays real music - dynamic, involving, exciting and tonally true. The most detailed and holographic amplifiers in the world. The tonal balance is exceptional.
Power output: 70 watts into 8Ω (mono)
Total harmonic distortion: 0.05%
Damping factor: 90
Signal to noise ratio: 95dB
Valve complement: 4 x 6C33, 5 x E88CC
Dimensions: 430 x 430 x 220mm
Weight: 30kg
This a Private Sale, there is no return, no guarantee and no exchange. The goods are sold under exclusion of any warranty. Shipping must be organized by buyer.
The Einstein OTL amplifier has, at its core advantage when compared to a conventional tube amplifier with output transformers, the ability to connect a loudspeaker directly to the output tubes. The sound quality limiting (and technical measured performance) output transformer does not interfere with the circuit. Frequency response, bandwidth, and phase linearity are in true OTL principle far superior and thus the typical Einstein sound is achieved via our design philosophy of offering ultra-fast, high bandwidth, linear phase, resulting in unsurpassed sound quality. Without the output transformer in the signal path, the amplifier controls the loudspeaker with absolute authority: you simply can not produce better sounding music.
These amazing amps retailed at €40,000.
More info here -
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Må hentes
Djgroovydawg
Fersking
Torget karakterer
Vurderinger (4)
