Hei,
Grunnet endring i oppsett ønsker jeg å legge ut min trofaste CODA for salg.
Spec:
Type: solid-state stereo power amplifier
Output: 300W x 2 into 8 ?, 600W into 4 ?, 2 ? load stable, Precision Bias Class A operation to 10 watts
Bandwidth: 5 - 100kHz
Distortion: 0.05%, 10 - 20kHz, driven into 4 or 8 ?
Amplifier gain: 26dB
Maximum current: >100 amp peak
Noise: > -100dBA referenced to 1V output
Slew rate: >50V per microsecond
Damping factor: >100
Input impedance: 50k ? unbalanced, 1k ? balanced
Power supply: 2.0 kVA toroidal transformer, independent rectifiers and 80,000uf low ESR supply capacitance
Dimensions: 17 W x 14 D x 5.5 H (inch)
Weight: 52lbs
Spec:
Weight: 52lbs
