T.C.B.
Bryston 14B-SST 2*600W/8ohm Solgt
Denne annonsen er utgått.
Effektforsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 30.000
Annonse beskrivelse
Annonse nummer: 46889
Selger et kraftverk av en highend Bryston 14B-SST i "mint condition" effektforsterkeren har 14 år igjen på garantitiden som er 20 år, da disse forsterkerene er håndlaget med deler fra de beste komponenter, som forsvaret, fly og romfarten bruker.
Nypris var rundt 79000,-
Kanskje den beste forsterkeren på markedet i forhold til pris...
Beskrives med ord som: Transparent, balansert, ekstremt oppløst, kontant og dyp bass, masse slam og dynamikk!
What HFL (Hifi Lounge) Thinks
Bryston 14BSST Dual-Channel (Stereo) Amplifier - Coming from Canada Bryston make some of the greatest HiFi equipment on the planet, whether you want one of their legendary amps, the ultimate Multi-Channel Processor, a pre-amp or a way to play the latest 24 bit music, Bryston have got it covered and more. Please check back shortly as we write our thoughts on each of their Products.
The Bryston 14BSST² dual channel (stereo) amplifier is basically two 7B?s which have been combined in a dual mono modular design and has the power to drive with breath-taking ease and clarity, speakers which have been considered "impossible" loads in the past.
Description: Solid-state, dual-mono power amplifier with balanced and unbalanced inputs. Specified output power (at 2kHz): 600Wpc into 8 ohms (27.8dBW), 900W into 4 ohms (26.5dBW). Distortion: 0.007%, 20Hz-20kHz. Intermodulation distortion: 0.002%, 60Hz+7kHz, mixed 4:1. S/N Ratio: 112dB ref. full output, input shorted, 20Hz-20kHz bandpass. Power bandwidth: 1Hz-100kHz -3dB. Damping factor: >300 at 20Hz, ref. 8 ohms. Input sensitivity: 2.2V unbalanced, 4.5V balanced, both for full output. Input impedance: 50k ohms unbalanced, 20k ohms balanced. Polarity: noninverting.
http://www.4audio.rs/upload/File/Bryston/Bryston review 49.pdf
http://www.bryston.com/PDF/Manuals/14BSST_MANUAL.pdf
http://www.audioreview.com/cat/amplification/amplifiers/bryston/14b-sst/prd_343908_1583crx.aspx
http://www.stereophile.com/solidpoweramps/725/index.html
www.bryston.com
T.C.B.
Torget karakterer
Vurderinger (9)
Andre annonser av T.C.B.
