Audio107
Audio Nirvana Alnico 12" Solgt
Denne annonsen er utgått.
Gulvhøyttalere
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Vestfold
Pris
Ta kontakt
Annonse beskrivelse
Annonse nummer: 85877
Selger ett par elementer i kasse. Kassene er "selvbygg" (se nr 3 fra venstre på bildet)
Drives lett av en liten forsterker.
KAN BYTTES I GULVSTÅENDE HØYTALERE..
PRODUSENTENS HJEMMESIDE:
http://www.commonsenseaudio.com/nirvana.html
The Audio Nirvana '
Super 12 ALNICO' ($849/pr) has a frequency response from 37 hz to almost 20,000 hz. You can expect at least 97 db efficiency in any of our cabinets. It handles 30 watts continuous RMS (normal listening level will be about 1/10 watt). Impedance is 8 ohms. Voicecoil is 1.5 inches (38 mm). Magnet weight is 2.4 lbs. Total weight is 15 lbs. The cone is made of paper. The surround is accordion style and made of treated cloth. The phase plug is copper anodized, machined solid aluminum. The Alnico magnet is made of aluminum, nickel, and cobalt and is stronger than normal ferrite/ceramic magnets. Our alnico magnet models are the smoothest Audio Nirvana models and make the most bass.
Audio107
Torget karakterer
Vurderinger (6)
Andre annonser av Audio107
  • Blacnote Dac 30
    Ønskes kjøpt av: Audio107
    Ta kontakt
