Moet Audio
Butikk AUDEL MAGIKA MK. 2 BOKHYLLEHØYTTALER demomodell til salgs
Denne annonsen er utgått.
Stativhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 25.560
Annonse beskrivelse
Annonse nummer: 242572
Nypris 42600 kr. Selges til demopris.
Stor lyd i små kabinett. Må høres.
Bookshelf without compromise.
After the success of the first series, we have implemented the quality of the tweeter and stiffened the cabinet to make it even more performing at the sound quality. Magika is the ideal bookshelf solution with an amazing value for money! With Magika mk2 we have shown that there is no limit to excellence.
The mk2 version presents the new Sb acoustic «Satori» series tweeter, featuring a decoupled black aluminum front flange. In this way the vibrations generated by the woofer and transferred to the cabinet do not affect the micro oscillations of the tweeter. Double compression balanced chambers for better dynamics. The 16cm woofer in polypropylene woven to obtain excellent damping, guarantees a uniform and extended frequency response. A unique reinforced rubber suspension reduces radial resonances.
IRS (Internal Ribs System)
a continuous research …
The new » rib » assembly system guarantees a mechanical stiffening of superior quality, as the alternating thickness acts as a bracing .
The resulting channels are used for a » reasoned » insertion of the sound-absorbing material, so as to prevent the formation of standing waves inside the cabinet.
The drivers are mounted on a 36mm plywood panel. The flare of the woofer is shaped so as not to cause the tube effect due to the thickness itself.
• SYSTEM: 2.0 integrated bass reflex
• CABINET: Multipanel System – Structure laminated birch wood
• TWEETER: 1st soft dome
• WOOFER: 5 1/2 » New Curv cone
• FREQUENCY RESPONSE: 40 Hz – 25,000 Hz
• CROSSOVER POINT: 2.400 Hz
• SENSITIVITY: 87 dB
• NOMINAL IMPEDANCE: 8 ohm
• POWER HANDLING: 25W – 120W
• FINISH: Birch cabinet – Ebony cover – beeswax surfaces
• DIMENSIONS: 380 x 200 x 288 mm (HxWxD)
• WEIGHT: 18 Kg pair.
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
