Som ny, spilt maks 200 timer så rørene er så vidt innspilt.
Kjøpt ny av meg i mars 2019.
Vanvittig kvalitet til småpenger. En virkelig drakedreper som spiser langt dyrere konstruksjoner til frokost!
Specifications :
CR type RIAA equalization, precisely compensated within +/- 0.3dB
Automatic, all tube voltage regulation circuit, ensuring exceptionally stable and quiet operation
High quality Moving Coil Step-up Transformers with Permalloy cores with variable gain (+22dB, +26dB, +28dB and +32dB) More on gain/loading later.
No negative feedback design
Pure Class A operation
Nyprisen var 37.000,- Erstatteren, H-5000 koster 39.000,-
www.lotushifi.co.uk
www.audiophilia.com
Specifications :
The new Allnic H1202 Phono | lotushifi
Allnic's new entry phonostage just got better again.
Allnic Audio H-1202 Phono Stage — Audiophilia
It’s interesting to note that a $3750 phono stage is now considered, among some audiophiles, as entry level for delivering vinyl sound as it’s meant to be heard. Sure, there are relatively inexpensive examples that do a fine job—the excellent Rega Aria is priced at $1500—and some expensive model
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
