TILLEGSOPPLYSNING:
Jeg har av flere blitt spurt om hvilke rør som sitter i. Det er meget gode, og dyre rør: Amperex 6922/6DJ8 og Mullard ECC83/12AX7. De beholder jeg gjerne, så kan selge uten rør, eller med rimelig rør for 25.000,-
Med Amperex og Mullard, 27.000,-
High end rør forforsterker, selges.
Dette er en av de best anmeldte forforsterkerene i internasjonal hifipresse. Skal man ha noe objektivt sett bedre enn dette, koster det veldig mye mer.
? Fully balanced differential circuitry with ability to internally balance a single ended input signal.
? Zero feedback.
? Discrete switched resistor volume control with 88 1dB steps.
? All tube amplification and output (4 tubes total).
? Two sets of XLR and two sets of RCA outputs per channel.
? Bypass mode for home theatre processor throughput.
? Absolute phase, selectable via front panel or remote control.
? Full function remote included.
Emballasjen finnes, så sending mulig.
Nypris + 70.000,- ($7000/£6500)
INNBYTTE I ANNEN SPENNENDE HIFI VURDERES ALLTID
Bare å søke på nettet etter omtaler.
For de som vil ha det litt enklere:
http://www.gong-av.ru/images/pdf/AesthetixHIFI2011.pdf
"hifi+ ?A new contender to my list of great line-stages?seemingly the hardest of all audio needs to fulfil?. The standard version is very good; the Signature is in a different league, its lack of musical constriction, character or emphasis allowing it to perform just as a great line-stage should?almost invisibly. Despite the relative brevity of its tenure it has already settled right into my system, trusted and relied upon in a completely unquestioning way. I love the way it just gets on with the job: no fuss, no drama and no drawing attention to itself.? (Roy Gregory"
http://www.theabsolutesound.com/articles/2016-editors-choice-awards-preamplifiers-5000-10000/
?The original Calypso remains a steal. The Signature will appeal to those who favor a more euphonic sound, a bigger soundstage, and significantly tighter bass. Both units offer superior performance, build-quality, and value.?
http://www.10audio.com/aesthetix_calypso-sig_atlas.htm
"Overall Ratings:
Calypso Signature Preamplifier: 9.5 LPs"
https://www.stereophile.com/content/aesthetix-saturn-calypso-line-preamplifier-wes-phillips-july-2010
"If you've got the money, Aesthetix Audio's Saturn Calypso Signature is a wonderful preamplifier that justifies its price. On the other hand, for $2000 less, the standard Saturn Calypso is still one heck of a great preamp?and it can always be upgraded to an even better one anytime you and your wallet are ready.?Wes Phillips"
Link Til Finn annonse med flere bilder:
https://www.finn.no/bap/forsale/ad.html?finnkode=150342706
? Zero feedback.
"Overall Ratings:
