Acoustic Solid The Machine Small
Innbyttevare
Veiledende pris: 39.990,-
The Acoustic Solid Machine Small is the entry-level product for our Machine range and is a simplified version our Acoustic Solid Machine model. Despite this, no compromises have been made in the key areas, including the use of our own high-precision «zero tolerance» bearing and a heavy 50mm thick aluminium platter to smooth out residual motor cogging. Nor have any compromises been made on build quality.
This is after all a German product. Instead of the decoupled outrigger type feet used on its larger brother, the Machine Small uses three independently adjustable spikes. Felt backed casters are provided to allow the turntable to be used on fragile surfaces.
OBS! spilleren selges uten arm
Innbyttevare
| Platter: | 50 mm thick aluminium machined from a single billet |
| Mat: | Natural leather with a 3mm thick acrylic layer |
| Motor type: | Synchronous |
| Control: | Microprocessor controlled power supply |
| Drive: | String-drive by a separately housed motor |
| Chassis: | 25 mm strong aluminum body |
| Dimensions: | 310 x 310 mm; 200 mm |
| Weight: | Approx 27 kg |
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
