"MEANT TO TRANSCEND EXISTING SOUND BARRIERS, THE NEW AUDIOVECTOR R SERIES BORROWS A LOT OF TECHNOLOGY FROM ITS BIGGER SIBLINGS, R 11 ARRETÉ AND R 8 ARRETÉ. TRUE HIGH-END SPEAKERS DO NOT COME MORE COMPACT THAN THE AUDIOVECTOR R SERIES."
Audiovector R-Serie
Navn:      r_series_7499.jpg
Visninger: 638
Størrelse: 65.6 Kb
A NEW LOOK WITH MUCH BETTER PERFORMANCE
A timeless classic has now been updated after 3 years of developing
• The R series reflects our “form follows function” concept
• The R series cabinet and baffles are minimum 25% stronger
• The R rear baffle is deeper, stronger and more solid for lower coloration
• The R 3 series plinth has more than minimum 30% improved airflow and a bigger footprint
• The R series front baffles use of a new lamination technique with improved resonance control
Navn:      audiovector r1.jpg
Visninger: 656
Størrelse: 79.6 Kb
NEW TECHNOLOGIES PROMISE A NEW WORLD OF DETAILS & DYNAMICS
Over dimensioned technology. Relaxed and detailed sound
• The R 3 Arreté AMT tweeter is our fourth generation AMT. Now with integrated S-Stop filter
• The R 3 tweeter is over dimensioned to the n-th degree. It reaches 53.000 Hz.
• New Evotech accelerated soft dome and damping material for the Signature models
• New Carbon fiber sandwich membranes promises increased detailing and improved soundstage
• New chassis for improved mechanical performances
• Second generation titanium voice coil technology for improved detailing
• Freedom Grounding® system brings a greater quality of musical reproduction and control
• 4th generation DFF low loss, low distortion filters for improved dynamics
Navn:      r_3_superstand_7890.jpg
Visninger: 624
Størrelse: 91.0 Kb
HANDMADE HIGH-END PRECISION FROM COPENHAGEN, DENMARK
Designed, Manufactured, Controlled and Tested by educated artisans
• Handmade open back AMT
• New drivers are designed and made by Audiovector in Denmark
• Crossovers are designed and hand built in Denmark
• All speakers are hand built in Denmark by educated craftsmen
Navn:      r_1_aa_7718.jpg
Visninger: 654
Størrelse: 129.1 Kb
MORE ABOUT AUDIOVECTOR FREEDOM GROUNDING®
We knew we could extract more detail and better dynamics. We found out how
• Freedom Grounding® removes unwanted distortion between drive units
• Freedom Grounding® connects to either artificial or true earth
• Freedom Grounding® brings spatial information forward
• Freedom Grounding® brings out hidden details unheard before
