Nyhet fra Lumin - T2
En godnyhet på nyåret! LUMIN T2!
Vi gleder oss allerede og som alltid så forventer vi oss det beste fra markedets beste streamermerke! Denne bygger på noe av teknologien fra toppmodellen X1 og erstatter A1 og T1.
Pris - 45.990,-
Why LUMIN T2
LUMIN T2 heralds the first redesign of the classic A1/T1 main boards and chassis. This new approach combines solid cnc panel construction with X1 technology to hit the performance sweet spot.
All-new chassis construction featuring thick cnc panels and an internal power supply
New generation processor provides DSD512 and 384kHz playback
Dual ES9028PRO SABRE DACS
USB digital audio output
Precision 32-bit internal digital volume
Discreet clock system for precision timing
Low-noise switching power supply with dual stage regulator
PCM & DSD upsampling
MQA full decoding
Roon Ready, Spotify Connect, MQA, TIDAL, Qobuz, Airplay and TuneIn
All-New Chassis construction
New CNC panelled construction offers upgraded structural rigidity and sheilding compared to the T1
The newly-designed thick cnc panels provide the high-end LUMIN family aesthetic
All the usual LUMIN refinements
From MQA to DSD, FLAC to WAV, LUMIN can play all the high-resolution formats you could ever want
Native support for TIDAL, Qobuz, Spotify and AirPlay, giving you access to tens of millions of songs
The unique and intuitive LUMIN App described as "the most convenient interface in existence" by Tinman
LUMIN programme of continuous development that has seen Roon, MQA, and Spotify support added in 2017 alone.
Tom Egil
Erdal Stereo
Spennende produkt og er den like god som A1, er den et funn til prisen.
Prebs
Spennende sak det her.
Spørsmål, Vil det bli kjørt en introduksjons kampanje på T2 tilsvarende som med U1-mini og D2 i 2018?
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
