Resultater 1 til 5 av 5
Abonnér på denne artikkelen
  1. Siste nytt fra Audio Analogue - MAESTRO ANNIVERSARY - integrert forsterker
    4 Kommentarer Av pmaudio - 18.10.2016 13:56
    Siste nytt på den nye stammen til Audio Analogue:: MAESTRO Anniversary
    15 års jubileum for Maestro
    Navn:      Maestro Front Sort.jpg
Visninger: 507
Størrelse: 36.4 Kb Navn:      Logo innvendig.jpg
Visninger: 505
Størrelse: 73.6 Kb Navn:      IMG_20160107_084241.jpg
Visninger: 492
Størrelse: 71.5 Kb Navn:      IMG_20160107_084212.jpg
Visninger: 527
Størrelse: 163.0 Kb Navn:      12496483_888367467944963_4374467351562803712_o.jpg
Visninger: 575
Størrelse: 46.6 Kb Navn:      IMG_20160107_083938.jpg
Visninger: 485
Størrelse: 39.8 Kb
    2 x 150W 8 Ohm
    2 x 300W 4 Ohm
    2 x 600W 2 Ohm
    kr 79995,-
    Maestro har fulgt oss med vellyd i alle disse årene - og nå har Audio Analogue løftet denne forsterkeren opp i den tunge enden av high end integrerte forsterkere.
    Står nå i fast demo hos oss på Nodeland - ved Kristiansand.
    For mer oversikt over "nye" Audio Analogue - PM Audio
    Kontakt oss her:
    e-post: pmaudio@online.no
    Tlf.: 38 18 31 15
    Maestro Anniversary was born in AIRTECH's laboratories following to the experience gained with the development of Puccini Anniversary. The basic scheme is very similar, but with one important difference: the amplification chain is fully balanced from the input to the power stage which becomes unbalanced to connect to the speakers. This took to a doubling of amplifier stages and attenuation. Also in the Maestro Anniversary all stages are without global feedback. The feedback is not even used on preamp stage(as in Puccini). The output power was increased to 150W on 8Ω with the consequent adjustment of all the driver and power stages that now use four pairs of transistors per channel. The basic configuration remains inverted cascode that is comparable to a single gain stage followed by the output buffer. The stability of the working point is maintained through a DC Servo that begins to work only at frequencies below a few tenths of Hertz (then totally out of the audio band). Thanks to a so refined circuitry, along with the selection of components of the highest level (military standard resistors, polypropylene audiograde capacitors custom made for AIRTECH, internal wiring with 7N OCC copper and pure copper output connectors) helped to create an amplifier that has the honor of being the heir of the glorious Maestro Integrated and therefore fully joins the Anniversary line celebrating at the same time, the first 20 years of Audio Analogue, but also 15 years by the introduction of AUDIO ANALOGUE's first product to bear the Maestro name. The new Maestro Anniversary is a unique amplifier, its remarkable power that always doubles with decreasing impedance and its extraordinary driving skills, are accompanied by a unique musicality and refinement not common for so “muscular” amps. Unfortunately it is not easy to express in words all its peculiarities and therefore we invite you to listen to it as soon as possible and can only confirm that now more than ever MUSICA MAESTRO!!!
  2. Antall kommentarer 4
    Hifi-entusiast ERIKD's Avatar
    Nov 2005
    Tagget i
    0 Innlegg
    Hørt rykter om den ja!! Kommer plutselig innom å hører, gleder meg
  4. #3
    Bransjemedlem Audiomix's Avatar
    Jul 2004
    Tagget i
    6 Innlegg
    Album
    Torget
    25
    Flott som alltid!
    Navn:      IMG_1669.jpg
Visninger: 301
Størrelse: 100.0 Kb
  5. #4
    Bransjemedlem
    Jun 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra ERIKD Se Innlegg
    Du er hjertelig velkommen!!!
    Jeg setter over kaffe`n med en gang!
    En mere fløyelsoppløst topp skal du lete lenge etter
  6. #5
    Bransjemedlem
    Jun 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra Audiomix Se Innlegg
    Flott som alltid!
    Navn:      IMG_1669.jpg
Visninger: 301
Størrelse: 100.0 Kb
    Her fikk du avbildet den rette definisjonen - fløyelskvalitet!!
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
