Reed Muse 3C
Vi har fått inn Reed Muse 3C platespilleren. En utrolig lekker platespiller med en interessant finesse som gir deg valget til å veksle mellom beltedrift eller mellomhjulsdrift. Man kan montere to armer for større fleksibilitet og det er innebygget sensor som indikerer at spilleren er i vater.
Den er koblet opp i vårt demooppsett og vi vil også demonstrere spilleren hos Duet som er Reed forhandler i Oslo senere i høst.
After more than three years idea-crunching and countless man hours of CADing, prototyping, programming and real-life testing, we built our first commercially available turntable - Reed Muse 3C. Is it somehow unique? Well, yes! Whether you are fan of friction-driven turntables (the famous Garrard is made that way), or if you think that the right way to build turntables is to use a pair of motors and a belt, Reed Muse 3C should catch your eye.Thanks to its unique and innovative design, you can convert friction-driven turntable to a belt-driven machine in 5 minutes.[h=3]What is inside of our turntable?[/h]After extensive prototyping and long-term experiments we came up to a solution of using a reverse sliding thrust ball bearing for a main axis. Bearing ball is made either from steel or ceramics and the lateral stability is achieved by using very durable and low-noise polymer sliding bearing. Symmetrical drive system is designed to avoid radial bearing load, hence minimizing possible mechanical noise and ensuring longevity of a master bearing.Muse 3C is powered by two direct current motors and by design is friction-driven, however its major innovation is possibility to convert it to a belt-driven system in minutes by replacing traction rollers and putting on a belt (and, of course, setting a switch to a correct position). To prevent possible mechanical vibration, we use traction rollers (be it friction or belt) of different diameters, spinning at different velocities and having mathematically non-multiple diameters to driving disc diameter. Disc velocity is stabilized by quartz-based phase locked loop (PLL) system, so average speed deviation depends solely on the parameters of quartz crystal. Turntable drive is equipped with both mechanical and electronic protection systems.Turntable also features electronic inclinometer (electronic level dedicated to measure turntable slope/tilt angle), which allows user to achieve perfect horizontal alignment without using additional tools.Turntable can be equipped with one or two tonearms with effective length ranging from 9.5” to 12”.
For info ta kontakt.
tom@endpoint-audio.com
47832922
eller via våre facebook sider Endpoint Audio
vidarn
Hva blir prisen Tom?
Audiomix
Ikke gjør som i videoen!
Det er eller blir mer kritisk med finger fett på reimer og hjul enn på rør.
Når en først skal demonstrere noe må det gjøres riktig.
oct
Uansett, bør en slik spiller settes opp av forhandler.
svartkeiko
9395 KALDFARNES
Nydelig spiller.De gutta der vet nok hva de holder på med.Og med Reed sine tonearmer bør nok denne være i toppsjiktet.Ja takk.
Mvh Kenneth
Endpoint Audio
Tønsberg
Den er utrolig enkel å sette opp, og rembytte til mellomhjul er så enkelt at det er laget for at brukeren gjør det selv. Tar ca 5 minutter.
oct
^^ Ok. Flott spiller, er det iaff;).
motoren
Flekkefjord
Det var faktisk en flott spiller som ikke ser ut som en olje rigg :)
LMC
Drøbak
1 av få "moderne" spillere som man får kjøpesug av........
bluesbreaker
Hundeeier
Blåskogen
Nydelig spiller.
Har hørt den i demo et par ganger.
Et av de beste alternativene når en er villig til å legge penger i en platespiller.
Powerpoint
Utvilsomt en lekker platespiller :cool:
Den vil stå seg godt sammen med topp notch drevet til CEC på husalteret.
Skal vi se onkel Bernard i Brooklyn begynner å bli gammel, så var det tante Greta....mumle mumle...
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
