Nyheter fra C.E.C. Nytt drivverk og matchende DAC.
CEC TL3 som har fått en rekke fantastiske tester - nå sist i Audio Fidelity - er erstattet med Drivverket TL5. Etter en rekke vurderinger anså CEC at TL5 var nær like god som TL3 og har valgt å fase ut denne til fordel for TL5.
CEC har også lansert ny DAC - DA5 til 39.990,-
TL5: 24.990,- På lager i sort og sølv finish.
Since CEC introduced world's first Belt-Drive CD Transport in 1991, a lot of music lovers have enjoyed its rich musical sound, which CEC continues to improve on. A heavier stabilizer brings a more stable rotation of the disc and the Belt-Drive system eliminates the affects of vibration and electromagnetic noise caused by the motor rotation.
In order to read the signal recorded with Constant Linea Velocity (CLV) on CD, rotation speed should be slowed down as it goes to the outside. Usually the spindle motor controls the variation of speed. All CD players and transports place the spindle motor beneath the turntable for CD and the motor shaft works as the turntable center, this is called directdrive system. Stable and accurate rotation requires a bigger torque of motor itself, which inevitably creates certain vibration and the electromagnetic noise. In CEC TL 5 the spindle motor is placed independently from the center shaft and vibration as well as electromagnetic noise effect to the CD are thus minimized. A heavy CD stabilizer provides bigger inertia of turntable and achieves a stable and smooth rotation of discs. Smaller torque motor and longer distance from the motor to the center shaft (turntable) create the ideal fundamentals of music reproduction.
The new CEC TL 5 features multiple digital outputs: AES/EBU, COAXIAL and TOSLINK. The shortest possible signal pass and stability of signal quality have been maintained by direct mounting of all terminals to the single circuit board. Superior Fluorescent display can be dimmed and even disconnected.
By placing the turntable shaft in the center of the top loading open space the rubber belt replacement is now done with ease on the CEC TL 5.
The word about the musical cohesion, the rich detail and emotionally gripping "analogue-like" sound got out very quickly. No other CD drive has sounded so analogue to this day. There has seldom been higher quality compact disc playback in this price class!
With the belt-driven CEC TL 5 in the system, one can benefit from the advantages of this type of drive. The newest CD belt drive by CEC helps improve the tonal progression.
Test reports in international magazines as well as the testimony of our satisfied customers worldwide confirm
that we have achieved our musical objective: music reproduction on its highest level.
tom@endpoint-audio.com
47832922
Medlem 1792
Ja, i dag fikk jeg i hus dette CEC TL5 drivverket og har nå spilt noen timer på det.
Dette var faktisk en stor overraskelse, at det var stor forskjell i lyden med dette drivverket kontra den CD spilleren jeg til nå har brukt som drivverk var positivt overraskende!
Janpe
Underskriver på at CEC er fenomenalt gode produkter. CD' en er definitivt ikke død.
JP
Endpoint Audio
Tønsberg
Takk for tilbakemeldingene. CEC er særdeles vellydende produkter og de innfrir. Snakket akkurat med en kunde som har en CD5 med innganger til den integrerte DAC'en. Han har testet flere eksterne DAC'er for å se om det var noe å hente, men konkluderte med at CD5 har en eksepsjonelt god DAC innebygd.
Helt enig med deg JP - cd'en er ikke død. Mange av oss har en god bunke - og personlig så foretrekker jeg det fysiske mediet over strømming. Jeg syns det låter bedre, og har funnet ut at drivverk har utrolig mye å si.
avon
Fersking
Jeg kjøpte drivverket CEC TL3N og DA 3N hos Tom Egil for en tid tilbake og kan ikke annet si enn at jeg er meget fornøyd med både handel og produkt. Jeg er også glad i det fysiske mediet. Det at man bruker litt tid på handlingen med å sette på en plate, føle forventningen og den velvære man fornemmer når man setter deg godt til rette.
Det blir litt mer nytefullt å gjøre den fysiske handlingen. Bruker også strømming jeg, men jeg finner ikke riktig den samme roen da det tidvis blir for lett å fortrenge de "dårlige" låtene. Det handler for meg mye om å finne roen...
CEC er solide, ærlige og nærmest skuddsikre produkter med en god signaleffekt, med det mener jeg at de ikke er prangende på noen måter. Drivverket TL3N er for meg en nytelse å bruke og det gir et " rolig analog" anstrøk til musikken. Jeg vet ikke hvorfor, men slik oppfatter jeg lyden når jeg spiller fra TL3N kontra å strømme musikk.
A.V.
impulse
Hølen
Jeg har vel sagt en del om hvor gode disse drivverkene er i siste Fidelity, og har ikke så mye å legge til. Hos meg var det en virkelig forbløffene oppgradering. Men de trenger noen timer for å gå seg helt til, så du blir nok enda mer fornøyd om litt, POM !
Medlem 1792
Ja, og når det verste oppgraderingssjokket har gitt seg er det kanskje på tide å «snuse på» en slik svindyr CEC-Wellfloat plattform til å ha spilleren på…:confused:
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
