Jeg har vært på utkikk etter rackmøbel som er solid og stødig samtidig som jeg ønsket treverk fordi det i mine ører har en heldig virkning på lyden. Erfaringsmessig så låter rørutstyr, cd spillere, dacer, solid state forsterkere og platespillere best når det blir satt inn i et tremøbel - i mine ører. Box furniture leverer førsteklasses håndtverk med flere forskjellige finisher - etter dine ønsker, eller med sine ferdig utformede løsninger.
Prisene starter på 25.000,-
Litt Fra Box om deres idé
mission
Our goal is to design and build elegant furniture in support of High Fidelity audio systems.
Extensive listening tests and careful materials consideration are integral to the creation of the BOX line of furniture. Just as the materials selection of a finely crafted musical instrument affects its tonal qualities, the BOX materials recipe is refined to best mate with the precise resolution and demands of High Fidelity audio components.
Our furniture is handcrafted in the USA utilizing the highest quality materials, mortise and tenon construction, and modern catalyzed finishes.
This combination of traditional craftsmanship, clean contemporary lines, and great sound will complement the finest of audio systems..
makers
Staffed by a talented and musical crew, BOX is born from decades of furniture making, record collecting, system tweaking, and sound engineering.
box furniture co
tom egil
tom@endpoint-audio.com
tom@endpoint.audio
47832922
mission
makers
box furniture co
tom egil
tom@endpoint.audio
47832922
