Det ble brukt en spesialutgave på messen av Kaisers toppmodell, mer informasjon finner du her hvis det er av interesse.
" Kaiser Acoustic’s Kawero! Classic loudspeaker is exceptional inside and out. This beautiful tower has a custom Raal ribbon tweeter that sits atop the system and has a built-in precision tool for placement, a 7-inch midrange driver, and a rear-facing woofer. This particular Classic loudspeaker is a special edition—one of only 30 pairs made—and retails for $100,000 per pair, though the non-special-edition Classics will set you back between $55,000 and $65,000 a pair.
The cabinet is made from tankwood, also known as Panzerholz, an extremely hard and dense compressed wood product made in Germany. Tankwood is sonically better than MDF, though it’s much more expensive—it’s basically bulletproof. The Kawero! Classic is finished in high-gloss wood paneling and can be ordered with internal or external crossovers ".
Pris i Norge vil noe rundt 800.00,- vil vi anta. Kun 30 par lages, løp og kjøp !
Teksten er herfra:
http://www.techhive.com/article/3021312/home-audio/10-jaw-droppingly-impressive-loudspeakers-from-ces-2016.html#slide10
Teksten er herfra:
111.1 KB Visninger: 2.820
