Aquilar - Ny High End tonearm fra Acoustical Systems!
Acoustical Systems lanserte nylig sin nye tonearm Aquilar.
Denne er basert på teknologien til Axiom, men til halve prisen.
Pris: 75.000,-
Beskrivelse fra konstruktøren:
Offering many of the superior choice and expensive materials, as well as most of the unique technical key solutions which made the AXIOM in its performance easily standing heads above all competition.
the AQUILAR features:
- 10” effective length (suitable for easy mount on ALL turntables - including Basis, AirForce Two and SME 20/30 etc)
- very easy and swift set up
- customized 3D-alignment template
- HD18 tungsten carbide counterweight - same as AXIOM
- unique acoustical-systems titanium/carbon-hybrid arm wand - same as the AXIOM
- precision leveling of bearing plane independent of arm board / turntable - same as AXIOM
- adjustable SRA, VTA, Azimuth, Overhang and Offset angle at headshell - same as AXIOM
- VTA on-the-fly - same as AXIOM
- non-touch magnetic Antiskating on-the-fly - same as AXIOM
- dynamic anti skating following the tangential curve - same as AXIOM
- design based on unique UNI-DIN geometry - available only in AXIOM and AQUILAR
- inner wiring is aged German origin fine 5N pure silver litz wire - same as AXIOM
- available with 2 terminal options:
direct-to-phono 1.2 m length phono lead
or
male DIN 5-pole connector
- available in 2 fine finishes:
black satin matt
or
ceramic-alloy bright silver matt (note: this looks just great - especially on Kronos, TechDAS AFO, TechDAS AFT and Sperling turntables!)
- available in 2 mounting versions:
with flat top mount plate (same as Tri-Planar , Jelco or DaVinci)
or
drop-in replacement for standard SME-mounting plate
Please note: the AQUILAR can drop-in replace TriPlanar, DaVinci, Jelco or Graham Supreme without any alternation to customer’s pre-drilled arm board!!
tom egil
47832922
tom@endpoint-audio.com
Endpoint Audio | – the ultimate destination for audio
svartkeiko
9395 KALDFARNES
Den hvite på bilde nr.2 var "snasen".Den skulle passe godt til den hvite Garrard 301:)
Har den samme kvalitet som pickup fra Acoustical Systems er det bare å sette denne som nr.1 på ønskelista.
Mvh Kenneth
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
