Resultater 1 til 3 av 3
Abonnér på denne artikkelen
  1. WhestAudio's REF V Mk IV phonostage - I EGEN LIGA - ankommet LYRIC HIFI
    2 Kommentarer Av LYRIC HIFI - 26.07.2015 22:14
    Navn:      Whest AUDIO ref V Mk IV rear for HIFISENTRALEN juli 2015.jpg
Visninger: 549
Størrelse: 118.3 Kb
    The culmination of years of design experience has finally lead to this - The MC REF V MK4 Phono stage by Whest Audio.
    It is unlike any other phono stage ever designed. The MC REF V is primarily designed as a moving coil phono stage with the minimum gain starting at 52dB and ending at 69dB, although 43dB MM gain can also be specified before the meticulous hand assembling operation.
    At the heart of the MC REF V MK4 is a newly developed fully discrete bipolar Class-A input stage. The noise level from this new ‘in-house’ designed device is lower than the best available monolithic IC chips available today but the advantages don’t stop there. The discrete design means sonic reproduction way beyond any monolithic IC available today OR tomorrow! The high output current of this device also means driving the new hybrid RIAA filters is done with absolute ease.
    The bipolar discrete stages operate in pure Class-A. The high voltage rails aid to achieve the staggering dynamic performance. Built into 2 matched mono-blocks each block contains a channel and power supply and each gain block contains 20 hand built and hand trimmed discrete Whest voltage regulators for near battery like impedance but without the battery ‘softness’ and ‘rounding’ of detail.
    The resulting effect is vinyl reproduction like you've never heard before.
    The large scale dynamics along with a 'real' life size soundstage are just 2 of the aspects that set the MC REF V MK4 apart from the crowd. Add to this its amazing resolving power and precise timing, its lack of 'signature' and its ability to play music like no other phono stage in the world, you can see why it is the envy of all other manufacturers.
    Technology:
    Pure Class-A discrete
    Dual mono gain-block design
    20 discrete voltage regulators per channel
    High current and high voltage
    52dB -69dB in 4 steps (MM optional)
    6 load and capacitance settings
    Hand selected parts used throughout
    Mange bruker mellom kr 50-100 000 på en god MC pick-up , så det bør ikke skremme de som opererer i dette prisområdet
    å legge noe i overkant av kr 100 000 på Whest Audio's Ref V Mk IV phono stage.
    Vi låner det gjerne ut mot depositum slik at du som er interessert vil oppdage hva som kan skje om du får dette inn i anlegget.
    LYRIC HIFI
    Torggata 28 , 0183 Oslo T
    t 22411984
    Velkommen !
    mvh Tor Aamodt Haug
    Vedlagte bilder
  2. Antall kommentarer 2
    Overivrig entusiast januscp's Avatar
    Jan 2012
    Tagget i
    0 Innlegg
    Anbefales på det varmeste
  4. #3
    Oct 2007
    Tagget i
    0 Innlegg
    Tusen takk januscp.
    Tor
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
