AXIOM - the real state of the art!
the Axiom fra Acoustical Systems!
En av markedets absolutt beste tonearmer.
Pris fra 148.000,-
Exclusive features of the AXIOM:
* VTF (vertical tracking force) non-touch-adjustment: on-the-fly - during play.
* SRA adjustment is independent from tonearm height (fixed mounting head)
* dynamic tunable effective moving mass
- from 22 gr to 42 gr effective moving mass in fixed mounting version.
- from 29 gr to 48 gr effective moving mass in SME-bayonet version.
* dynamic antiskating
- w/exchangeable inserts for any tangential curve!
* carbide hardend titanium / carbon-composite arm pipe with
internal liquid dampening on whole inner surface.
* exchangeable inserts in counterweight tuned to cartridge's compliance.
Thus eliminating low frequency resonance peak.
* the AXIOM and it’s bearing axis can be precisely leveled on it's own. This is independent from the plinth's level and done with 3 precision set screws around the center mounting screw (these are covered by the large round metal cap and not visible when mounted).
All these features listed above you will find in the AXIOM only.
General features of the AXIOM:
* the AXIOM is a full dynamically balanced design
* the AXIOM is a full lateral balanced design
* the AXIOM is a special 12" design with mounting distance of 9-10" tonearm
tom@endpointaudio.no
47832922
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
