Micromega MyDAC til KUN KR. 2995,- ! er en av 3 produkter i MyRange serien : DAC, Hodetelefonforsterker og Phonotrinn(RIAA).
I MyRange Serien fra Micromega vil det komme en trådløs streamer, en integrert forsterker og en cd spiller.
Micromega MyRange serien gir våre kunder produkter til lave priser men samtidig ekstremt høy ytelse som vi er svært glade for å kunne tilby.
Micromega MyDAC har tatt verdenspressen med storm, her med utdrag fra The Absolute Sound :
"I dropped the MyDAC into my reference system and was shocked by how good it sounded for the price. The Micromega gives you some sonic attributes usually reserved for much more expensive DACs—qualities like air around instruments, a sense of three-dimensional space, and a laid-back sense of ease. Through the Micromega, instruments don’t sound like flat cardboard cutouts; they are instead fully fleshed out three-dimensional images surrounded by a wonderful bloom. In these qualities, the Micromega’s sound would not be out of place in a $2000 DAC. Timbres are remarkably smooth and free from grain. The bass is solid and tight, although the very lowest bass lacks ultimate authority."
''It’s worth an audition even if you were planning on spending quite a bit more. You might find, as I did, that this level of performance for four-hundred dollars qualifies as a miracle.''
– Robert Harley, The Absolute Sound
Micromega MyDAC kan fås i sort og hvit finish.
Spesifikasjoner :
For mer informasjon, ta kontakt med navn, adresse og tlf nummer : mail@hifistasjonen.no Forhandlere kan ta kontakt på : forhandler@hifistasjonen.no Tlf nummer 62416121 Mobil : 40850814 WEB : Hifi Stasjonen - Main site Produsentens websider : Micromega-Hifi |
