Resultater 1 til 1 av 1
Abonnér på denne artikkelen
  1. Clarus lanserer Crimson high end USB kabel
    0 Kommentarer Av Intrepid-AV - 27.09.2013 14:17
    Clarus® proudly introduces a USB cable for the Crimson Series, specifically designed for High Speed USB 2.0
    The engineering of the Crimson USB cable is the result of careful consideration of the complex issues associated with the design of digital cable, namely the preservation of signal integrity including minimization of jitter and the elimination of noise. To satisfy these design requirements, the Crimson USB cable is manufactured from heavy gauge PCOCC copper, Pure Copper by the Ohno Continuous Casting—a process that yields the purest copper available today. The USB features 20AWG power conductors to ensure there is adequate current flow to USB audio devices.
    To reduce jitter and timing issues, the Crimson USB cable is manufactured using high-precision wire twisting machines that ensure perfectly match twisted pairs. Skin effect is minimized by plating the solid-core PCOCC signal conductors with 6.1% solid silver. For noise elimination, there are effectively six layers of shielding to prevent the power signal or outside EMI/RFI from corrupting the digital USB signal. This heavy-duty protection also prevents emission of the high frequency USB signal from the cable, which if leaked, would adversely effect nearby cabling and electronics.
    Like all Crimson Series cables, the new USB is covered with an attractive black and red woven jacket, complemented by painstakingly meticulous hand-craftsmanship.
    Clarus Crimson USB blir tilgjengelig i oktober i 1 og 2 meters lengder til utsalgspriser henholdsvis NOK 1 999,- og 2 999,-. Vi tar i mot forhåndsbestillinger nå og vil allerede bestille 1. batch i starten av oktober.
    www.intrepid-av.no
    shop.intrepid-av.no/categories/usb
    Siste redigert av Intrepid-AV; 27.09.2013 kl. 15:20.
  2. Antall kommentarer 0
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
