Conrad Johnson lanserer et nytt rør RIAA-trinn som skal være
"state of the art" for de som elsker LP plater, og kjører
ubalansert. Prisen er Kr.99 000- veil.
Lew Johnson hadde dette å si til Stereophile på CES:-
"The TEA1 triode equalization amplifier embodies our current understanding of the state-of-the-art in phono stage design. It's a zero loop feedback design with two tube gain stages and a passive equalization network. We put a high-current buffer stage isolates the unit from cable and other loading elements."
Anything else?
"Well, yes. It has two inputshigh gain and low gain with adjustable resistive and capacitive loading."
AUDIOFREAKS stiller ut trinnet aktivt på Horten messen.
peterd@online.no
www.audiofreaks.no
www.conradjohnson.com
Anything else?
peterd@online.no
www.audiofreaks.no
24.9 KB Visninger: 12.015
