Paul McCarteny & Wings - Band on the Run - High Resolution 24bit 96kHz download.
torsken
Denne må dere ikke gå glipp av.
Hvis du har mulighet for å spille av 24bit 96kHz filer anbefaler jeg denne på det sterkeste.
Jeg har skaffet meg versjonen uten komprimering og den låter som ei kule. All dynamikken er på plass, lite eller ingen bruk av no-noise, og i tillegg uten løft i diskanten. Kjempelyd.
Gjør din plikt og kjøp denne slik at sjangsen for flere nyutgivelser med samme kvalitet øker.
PS. George Harrison - All Things Must Pass blir sluppet 26 november i 24/96.
http://www.paulmccartney.com/bandontherun/
torsken
"High Resolution Details
The audio industry has seen many technical innovations since Band on the Run was first released on vinyl in 1973, the most notable being digital recording. However, with the introduction of CD came two advances, “de-noising” and “peak limiting” which have become increasingly unpopular within certain areas of the music industry and amongst audiophiles.
De-noising was introduced to remove the inherent sound, or hiss, associated with analogue tape. The amount of processing used to remove tape noise can be varied, but when used excessively, many believe that it also has a detrimental effect on elements of the musical sound.
Peak limiting is a process that increases the loudness of music. It is achieved by holding the loudest peaks down and raising the overall level of the music. Much depends on the amount of limiting applied, but at its most extreme the result can be a serious reduction in the dynamic range and often audible distortion.
The release of The Beatles’ remasters in 2009 saw a marked change in attitudes towards these issues, where both noise reduction and limiting were used sparingly with the aim of representing the master tapes more accurately. Such is the case with the newly remastered CD of Band on the Run: tape noise reduction has scarcely been used and the degree of limiting is subtle. In addition digital technology has advanced with the ability now to offer recordings in 24 bit/96kHz. The high resolution version is being made available via download and is being offered in two formats: limited, which is comparable in volume to the remastered CD, and un-limited, which in comparison with the limited version will sound quieter, but retain the dynamic range of the original master recording.
Allan Rouse Abbey Road Studios"
pstraums
Flateby
Det rykker i bestill-fingern! spørs om ikke det blir et par hires handler i helga (denne og eidsvåg fra gubemusic)
Håper det blir MER slikt som dette i tiden som kommer!
I like! :)
baluba
Kopervik og Bergen
Jeg har lenge antatt at det er slik fremtiden vil bli med artister som har budsjett til det, nemlig to versjoner for nedlasting. En lett komprimert, en mer "moderne og populært" komprimert. DET er en av de store fordelene med å gå over til digital distribusjon, og det argumentet som kan få drivverkfolket til å revurdere sin mekanisk-optiske fetisj.
torsken
Parelius skrev:
Med vs. uten “peak limiting”: Utvilsomt stor forskjell.
Med vs. uten bruk av "de-noising": Utvilsomt stor forskjell.
24/96 vs. 16/44: Kan diskuteres.
De 5 viktigste faktorer for best mulig lyd etter min mening (i tilfeldig rekkefølge):
1. Bruk av best mulig kilde (helst mastertape).
2. Ikke bruk av “peak limiting”.
3. Ikke bruk av "de-noising".
4. Ikke unødvendig mye energi i toppen (diskant).
5. Så bredt stereo perspektiv som mulig.
24/96 (un-limited) versjonen av Band on the Run treffer blink på alle punktene.
ottone
Fint å slippe "peak limiting", det er klart, og det går fint innenfor Redbook standard også.
Men er disse utgivelsene faktisk samplet 96kHz eller høyere fra analog master, eller er det (igjen) bare upsampling fra 44kHz ?
Jeg blir skeptisk når de ikke oppgir det tydelig midt i alt det andre skrytet. Hvis det var virkelig high-rez var det det første jeg ville nevnt. Hvorfor da ikke si det rett ut?
Her er bølgeformen og spektrumet av de første par minuttene av "Band on the Run":
Utemmet dynamikk i bølgeformen og fortsatt noe informasjon i spektrumet godt over 20 kHz. En litt mistenkelig topp ved 21.6 kHz, men fortsatt -90 dBFS ved 30 kHz.
Imidlertid, slik ser en ekte HiRez-innspilling ut. Det er "R for Riddle" fra Mike Mainieri "Live in Rainbow Studio", med Jan Erik Kongshaug ved spakene. Resonanstoppene ligger over 30 kHz, og det hele ser fornuftig ut ganske langt oppover.
Det er ikke godt å si hva som begrenser i hvert av tilfellene. Hvilken båndbredde hadde mikrofoner og analog mastertape? Derimot er jeg ganske sikker på at jeg hører dårlig oppe ved 30 kHz og deromkring.
nma
Syns denne lider litt av problemet som Beatles-remasterne har. De har sikkert brukt all den seneste teknologien, men det er ikke gjort puristisk nok + det er litt EQ inni bildet. DCC-utgaven har en varmere og finere klang, selv om den ikke låter like detaljert, uten at jeg tar stilling til om det er p.g.a EQ eller annet. Jeg har egentlig bare hørt første sangen.
Kikket på filene igjen. Her er spektrum som funksjon av tid, fortsatt de første minuttene av spor 1, "Band on the run". Da er det lettere å se at noen av toppene er ultrasoniske opp til 35-40 kHz. Denne er hirez, ja. Vet fortsatt ikke hva den streken ved 22 kHz er. Den ser ut til å være korrellert med signalet på en eller annen måte. Resonans i en mikrofonmembran?
Her er Mainieris "R for Riddle" igjen, vist på samme måte. Den er innspilt i DSD-format, og det er gruelig mye ultrasonisk støy som følger med på kjøpet fra 30 kHz og oppover.
Steinar_Lund
Hvalstad, Asker
Vet du hvor man kan kjøpe All Things Must Pass for nedlasting?
Wergeland
georgeharrison.com
Steinar_Lund
Hvalstad, Asker
georgeharrison.com
Takk. Men når jeg prøver der, får jeg visst bare lov til å laste ned Chants of India. Får prøve senere.
Apropos ex-Beatler, noen som vet noe om lydkvaliteten på nyutgivelsene av Lennons plater? Remixed ("stripped down") og remastered - det er ikke nødvendigvis et godt tegn.
Wergeland
georgeharrison.com
http://www.georgeharrison.com/#/all-things-must-pass-40th-anniversary
Scroll litt ned. $29.99 for 96Khz/24 bit flac.
High_def
Hei! Litt sent ute, men synes det er verd å gi en respons her.
Har fått ned Band On the Run, McCartney og McCartney II på 24/96 unlimited.
Dette er virkelig STRÅLENDE arbeid. Kjenner disse svært godt fra før og mener disse filene overgår tidligere digitale utgaver glatt.
Høydepunktet er McCartney. Litt varierende i musikalsk kvalitet, men lyden er den beste så langt - uansett format. Det har vel mye å si at innspillingen og etterproduksjonen av skiva var svært spartansk. Det som en får her er vidunderlig.
Slik kan flere artister også gjøre!
Selv om jeg har betalt for skivene til macca ganske mange ganger nå, så gjør jeg det gjerne en gang til hvis dette er resultatet.
Glad nå! :D
