ProAc D-48R. Du må komme og HØRE hva Stewart har fått til nå - hos LYRIC HIFI
Du inviteres til store musikkopplevelser fra ProAc D-48R høyttalerne.
Disse er bestykket med 2 stk basselementer ned "carbon fiber pulp" cone og bånddiskant.
Det er meget vanskelig å få integrert og tilpasset elementer mot bånddiskant
slik at man får en overgang mot mellomtonen som føles sømløs.
Info sakset fra nettet :
The ProAc D48R is identical to the D48, however utilises a ribbon tweeter.
ProAc have improved the mid-range detail and a opened up a cleaner, faster and more extended bass response. A new studio monitor quality bass driver was designed for the D48, featuring a special impregnated cone and mid frequencies tuned by a cap of greater size than standard. This gives the new unit greater mid-range detail along with excellent bass control giving a tighter and more extended response.
The two new bass drivers are each loaded through ProAc's special floor loading with side vents, this makes the loudspeaker easier to place and reacts less to surroundings. The two bass units are then seamlessly mated to our ribbon or dome tweeter depending on your preference. With such a large slim floor standing design the sound stage is superb being very large and with pinpoint imagery. Another achievement for the D48 is its ability to create large orchestral works as well as heavy rock music.
The D48 has a high quality filter network designed by Stewart Tyler comprising of the finest components, ProAc cable on a special board. The filter is also split for bi-amping and bi-wiring. This is one of the best designs from ProAc and should please all audio files regardless of their taste in music.
ProAc have moved away from the carbon fibre cone material utilised on the D40, instead opting for a carbon fibre pulp which delivers improved midrange frequency reproduction as well as tighter bass with less low frequency hangover.
These differences give the listener a more detailed, open midrange and a more expansive soundstage. Also, the leading edge of bass instruments is more audible with less muddling in comparison to other carbon fibre based drivers.
Vi kan demonstrere med både rør og transistor etter ditt ønske, men de står p.t.
oppkoplet med BRYSTON forsterkersett.
Kom og hør hva legendariske Stewart Tyler har fått til med disse.
Avtal når du ønsker å komme.
Velkommen !
Tor Aamodt Haug
LYRIC HIFI
Torggata 28 -0183 Oslo
tlf 22411984
mail : tor@taaimport.no
QWERT
Nå er du i farta. Beste butikk inne hifi har du. Stå på, Tor.
Bergfinn
Blir stadig fristet av ProAc her Tor.
Jeg tørr ikke avtale time.
Har ikke råd. :cool:
B
LYRIC HIFI
Hei QWERT,
Slike kommentarer gir skikkelig "krutt på mølla" til å stå.
Tusen takk.
mvh Tor
LYRIC HIFI
Hei Bergfinn.
Du må bare ta turen innom.
Ta med deg skivene dine og du kan ha rommet for seg selv og jeg skal ikke plage deg for mye med kjøpepress.
mvh Tor.
Bergfinn
Takk Tor. Long time, no see. Hadde vært hyggelig med en ny preferance på denne "brukskunsten".
En stund siden modellracet jeg pløyet gjennom på 90tallet.
Tipper det har skjedd litt på 15-20 år.
B
gismo
Væssia i Grue.
Flotte talere, får vel prøve å ta en tur til tigerstaden;)
gismo
E.I.A.
Og prisen for Best HifiShop Norway goes to Lyric Hifi :)
Gleder meg skikkelig til mine D48R står i stua, disse tror jeg er noe helt spesielt8)
Gismo@ Disse er nok allt for store for deg, blir overdose av godlyd ;)
mana
Ser fantastiske ut og de låter helt sikkert helt fantastisk også :)
Ketil
Frister litt disse, skulle likt å se en test med disse og f.eks PMC 26 Twentysix, PSB Imagine T3, Sonus Faber Olympica II, Respons Grand Artist.
gismo
Væssia i Grue.
Så så E.I.A.:rolleyes:.....jeg har fått riktig størrelse og riktig mengde godlyd i stua nå, så så mye mer tåler je itte:cool:;)
gismo
sense
Rørvik i Nord-Trøndelag
Hadde en sjelesettende opplevelse for mange mange år siden i butikken din.. husker ikke typebetegnelse,men det var Proac:) tror det var noe klasse A Accuphase innblandet... og må bare si at fristelsen er STOR;) når jeg ser hva du pressenterer her. Stå på..dette kan du:)
sense..
nilsen64
hvorfor kan ikke tor ha nettside som andre og legge ved prislister?
vel ser at i uk koster de litt over 6000 britiske pund så da vet vi vel sånn cirka hva herligheten koster..
frister (har hatt d15 før)
Bergfinn
Hadde Response 3 og mange andre, savner Response 2 mest. Dagens modellutvalg låter sikkert enda bedre.
Tror nok D48R hadde blitt bedre mottatt av min andre halvdel enn det som står i heimen nå.
Eller er det min bedre halvdel det heter kanskje...
B
E.I.A.
Hovedgrunnen for det er nok vekslende valutakurser.
Tor tar utgangspunkt i kursen den dagen det blir bestillt, da får du alltid en mer riktig pris i forhold til de som legger inn store marginer for og ta opp svingninger i kursen.
skorob
Brumunddal
Ikke alle produsenter(som f.eks accuphase) som tillater at prisene er tilgjengelige på nett. (ikke alle som bryr seg om det men..).
LYRIC HIFI
LYRIC HIFI sine annonser
SOLIDSTEEL eksklusiv import og salg tilbake hos LYRIC HIFI , Torggata 28 Oslo
  • 1
Since their introduction in 1991, Solidsteel audio tables have established a new level of technical and aesthetic refinement for audio and video component support and isolation...
Nye STAX SRS-5100 = SR-L500 elektrostat hodetelefon & SRM-353X driver ankommet
  • 5
STAX SR-L500 elektrostat hodetelefonen og SRM-353X transistor driver/forsterkeren bringer musikk til ørene med detaljer og kvalitet som er fantastisk med stor opplever en fyldig og dyp...
Helt ny modell ProAc DB-1 ankommet. Kom, lytt og glem hverdagen ! LYRIC HIFI
  • 15
Stewart Tyler's magi igjen på sitt beste. Ord blir overflødig, må oppleves ! Herlighetene kan erverves for kr 24 950 pr par for Standard finish og kr 27 560 pr par for Premium finish. For...
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28
  • 4
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28 For MC pick-up’er med høy oppløsning Som alle Whest Audio' s design har whestTHREE Signatureblitt laget for...
Vi inviterer til demokveld med FOCAL La SCALA mk 1 tirsdag 2. fra 16.00-20.00
  • 2
Seansen vil foregå i våre lokaler i Malmskriverveien 11 eller Torggata 28 Vi informerer nærmere om hvor dette vil skje avhengig av hvor mange melder ifra at de vil komme. Mail påmelding om du vil...
Vi inviterer også til demokveld med ProAc D-48R torsdag 28. januar fra 16.00-20.00
  • 8
Seansen vil foregå i våre lokaler i Torggata 28 med enkel servering og den største musikalske opplevelse ! ProAc har i alle år fått kun glimrende skussmål av musikkglade brukere som ikke så...
