Forsterkere Abrahamsen forsterker
hansa-bergen
Når kommer de forsterkerene for salg, er det noen som vet noe om de?
Her er data på utstyret.
The following products are under development / production and will be lounged within Q2 2012.
Integrated amplifier Aeris
2X100W into 8 Ohm, 2X150W into 4 Ohm, will drive loads down to 0.5 Ohm 3 analogue inputs (1 balanced and 2 RCA)
1 USB input
1 Coax / Toshlink spdif input
1 spdif output
USB and spdif inputs are up sampled to 24bit 192 KHz 1 adjustable sub output
1 headphone output (1/4 “jack)
Fully remote, individual volume setting for each input.
Size: W 43cm (17”), H 12cm, D 32cm Weight app. 16Kg
Preamplifier Apertus
3 analogue inputs (balanced and RCA)
4 digital input ( 1 USB and 3 Toshlink / Coax) Up sampling from 16 bit to 24bit 192Khz
1 dig output (spdif)
Balanced and single main output
Dual power supply
Fully remote, individual volume setting for each input. Size: W 43cm (17”), H 12cm, D 32cm Weight app. 8Kg
Poweramplifier Aperire
2X100W into 8 Ohm, 2X150W into 4 Ohm, will drive loads down to 0.5 Ohm Balanced and single input.
Link output. Link more power amplifiers together for bi-amping.
Mono amplifier Amplus
230W into 8 Ohm, 420W into 4 Ohm, will drive loads down to 0.5 Ohm Balanced and single input.
Size: W 30cm (12”), H 22cm, D 42cm Weight app. 20Kg
A-DACII: USB/ S/spdif DAC with balanced output and separate power. A-DACIII same as V6 but with 24bit 96KHz USB input.
Ampliwire
Finnmark
De kommer nok aldri i salg, Abrahamsen er relativt passive.
Tror ikke de produserer noe særlig av V- serien heller lenger
NLS
Drammen
Nej det var en mærkelig historie med monoblokkene (var det V5 de hed?). Salget var klart, salgsdemonstrationer var annonceret, specs offentliggjort, billeder viste blokkene i setup. Og så... tavshed.
Et eller andet skete.
Tror heller ikke på nye produkter før jeg ser det. Men fortsat sælges den gamle produktrekke, som er glimrende produkter innenfor sin klasse. Good value for money.
Ampliwire
Finnmark
De som er avbildet er ikke V5, men det var snakk om noen andre blokker. Disse skulle være i samme serie som ble solgt på elkjøp (V-serien).
Mener å huske at det er en brokoblet V4, med noen ekstra utgangstransistorer i ett ''mono'' chassis. Ble vell laget noen prototyper av denne mener jeg å huske?
javerion
kan det være at de kommer med noe nytt utstyr igjen? det var vel en referanse serie på vei tidligere, men disse kom aldri for salg. kan det være en oppusset variant av denne tro?
nittenfemtitre
Os, Hordaland
Skulle gjerne sett monoblokkene i salg. Noen som har hørt noe mere?
Ser innlegget var fra mulig lansering 2012. Egentlig gammelt nytt.
Går ikke fort hos Abrahamsen.
X-Cell
Lorden av Nord!
Det er vel noe på gang.. men klart, det begrenser seg nok i tempo da det tross alt ikke er noe stor bedrift.. men små fugler sier helt ny serie i 2018..
NLS
Drammen
Et stykke tid siden jeg har snakket med Per Abrahamsen. Da var planerne nye modeller distribueret bredt i Norges land. Modellerne har han sandsynligvis haft klar længe, men produktion og distribution i større skala er vanskeligt når du starter fra nul. Det kræver først og fremmest masse risikovillig $$. Her har det strandet. Længe.
IMO bør Abrahamsen holde sig til sit lille firma, med samme forretningsmodel som idag. Sælge enkeltvis på bestilling, minimum varelager. Med tiden kan det så vokse.
Strømling
Nedre Romerike
Elsker min V2up en litt større forsterker fra den kanten hadde jeg kjøpt umiddelbart.
NLS
Drammen
Ditto! Har ganske vist "bundet mig til masten" med Beolab 5 her is stuen (og det blir ikke bedre innenfor mine økonomiske rammer), men klar til nye eventyr på Herreværelset :) Havde købt nyt fra Abrahamsen uden at blinke.
hansa-bergen
De jobber med en ny serie med produkter også nye og forbedrede DAC`r.
Disse vil være klare for markedet til høsten. Så nå er det bare og vente i spenning, gleder meg til og høre den nye Dac'en deres.
Dazed
Hadde vært flott, men vi har jo hørt det samme ørten ganger før. Håper det stemmer.
baluba
Kopervik og Bergen
Krysser fingrene for det. Min erfaring med A-DAC gjør at jeg ser fram til en ny DAC fra den kanten, kan absolutt bli et alternativ å vurdere. Men som påpekt, vi har hørt slike rykter litt for mange ganger nå. Har likevel troen på at en ny serie vil komme til slutt.
Eirik84
Drammen
Hvis den dagen faktisk kommer er det jo veldig spennende! :)
v6.0-DACen legges jo for tiden ut på Torget og Finn for over nyprisen de ble solgt for i butikk, så føles bedre da om det kommer noe nytt. En type v6.0 med fjernkontroll hadde vært kjærkomment..
X-Cell
Lorden av Nord!
Som det sies her så blir det litt sånn "tror det ikke før vi ser det..".
Det er jo synd det har blitt slik for min mening er t Abrahamsen fortjener livets rett og jeg håper de kommer med noe nytt før det er for seint.. jeg hadde uten problem kjøpt monoblokker i type aw180 chassi med v40 up brokoblet innvendig.. hører flere som har sammenlignet v40 brokoblet opp mot aw180 det v40 har stukket av med seieren..
Personlig jakter jeg jo nå på monoblokker.. og 2stk v40up med v30up er ikke uaktuelt..
nittenfemtitre
Os, Hordaland
Abrahamsen 2018
Hei alle.
Godt nytt år. 2018 nå og håper de snart kommer med noe nytt fra A.
Tenkte meg gjerne noen monoblokker. Har jo vert snakket om siden 2012, minst.
Da var det snakk om V5. Litt senere en helt ny serie. Håper det snart skjer noe.
Kanskje også en dac med mulighet for fjernkontroll.
Krysser fingerene.
Noen som har hørt noe?
mediakjendis
Ser på dataen på forsterkerne at de skal klare laster ned mot 0.5ohm,Det er jo nesten kortslutning. Det trur jeg er en sterk overdrivelse.
hansa-bergen
Snakket med de i dag det tar ca 2-3 månder til alt er klart med ny serie, jeg venter i spenning på ny dac. Er meget fornøyd med deres produkter.
