5 forskjellige nye platespillere.
HasseBasse
Hjortshøj, Danmark.
http://www.thevintageknob.org/pioneer-PL-L1000.html
Se nederste billedet til høyre. Samme princippet som Sony brugte til at drive laser i deres gamle, dyre CD-spiller.
The entire chassis of the PL-L100 is aluminium and weighs a ton. This top chassis sits on the lower chassis by 4 spring/rubber suspension that also act as the feet. The tonearm does not sit on any chassis, instead it is it's own entity and sits, motor and all, on guide rails with it's own suspension system. Very effective at not picking up external vibrations. Most every tonearm follows the record groove on relying on friction to "guide" it to the inside of the record (with the proper amount of anti-skate to counter balance this friction). The PL-L1000 uses several motors, not friction, to guide the tonearm at any time once powered up. This makes for a very accurate tonearm tracking system that does not need any anti-skating applied. The entire tonearm assembly floats on a magnetic rail system to slide across the record, and it uses another motor to raise and lower the tonearm assembly when cueing. There are many motors, but the cool thing is that in the manual mode, you can use the front mounted dial (actually another motor) to move the tonearm across the record in very fine increments - a nice touch. There is one drawback though, if the entire turntable is not level, the whole tonearm will "skate" by itself across the record, kinda acting like a anti-anti-skating feature that you don't want. You MUST level this unit, and the amount of adjustments that one needs to make on this unit is outright scary. The design is one of pure simplicity and almost linear tracking perfection. Once set up it works beautifully.
Fra: http://www.audiocostruzioni.com/r_s/giradischi/pioneer-pl-1000/pioneer-pl-1000.htm
Audiophile-Arve
PL L 1000 er ein kjent storleik (har faktisk ståande ein her, i varetekt for dotter mi, som ikkje har fått seg akseptabelt lytterom endå). Veldig god arm til ganske mange, og litt tunge pickupar. Dessutan eit svært godt drivverk.
Er dette altså den same spelaren som "Magnetic Rail System" du nemnde?
HasseBasse
Hjortshøj, Danmark.
Yeppps :)
For at forklare det lidt simplere.....
Oppe i huset ved armens "pivot point" sidder en veldig lille pcb med 2 photosensorer, en på hver side af centrum.
Nøjagtig justering af disse resulterer i, hvor lidt armen skal lese ved siden af centrum, før den beveger sig på plass igen.
Mener den kan komme ned under 0,1% "tracking angle" avvik.
Men fordi de to "guide rails" er åbne opad, kan der samles støv på dem, som sammen med smøremidlet på dem kan danne "klumper" der gør,
at den ikke kører jevnt. At holde dem helt rene + de 4 rollers med tilhørende lejer er et "must" :)
Og som det også står hos Audioconstruzzioni...... Den skal stå ABSOLUT 100% i water.
Reaksjoner: oct
Motorhome
Sunndalsøra
Etter som jeg har forstått, Så er Pioneer PL-L 1000 veldig følsom for vribrasjoner på gulv, selv om den har flytende oppheng som er justert optimalt. Det kan være den linærtracking systemet til tangentarmen som er årsaken?Har vært bort i både Bang&Olufsen og Systemdek IIX uten dette problemet m. et ennå mer svaiende gulv enn demoen vist på YouTube. Hvilke tiltak som hjelper på denne spilleren, vites ikke. Det var ganske små vibrasjoner som skulle til hær!
Dette problemet kan ikke løses på sentralen men hjemme 🙂
HasseBasse
Hjortshøj, Danmark.
Har haft PL-L1000 ad 3 omgange, men selger den altid igen, da mit indtryk er, at den lyder kønsløst/umusikalsk uanset de fantastiske konstruktions-
principper, den er gjort med.
Har oplevet lidt det samme som dig, men har isoleret det til en ting: Kompliance på benyttede pickupper. Med stivere pickupper med nåletryk på 2+ gram, var det ikke noget problem hos mig :)
Audiophile-Arve
Ikkje verre enn ein sl 1200
Auditor
Hvalross: Det virker ærlig talt på meg som om du ikke er rede til å bytte CECen enda.. Da syns kanskje jeg at du skal beholde den etpar år til, bli bedre "kjent" med den. Og finne ut hva C-Plugger er for en pickup. Du kan være sikker på at RIAAen din vil holde mål til den dag du selv finner ut at det faktisk er verdt å betale det ekstra det koster bytte ut CEC. En entydig bedre samling oppgraderinger er listet opp allerede her, men hvis du ikke er villig til å betale for den av de du måtte velge, vent!
hvalross
Jo,da ,jeg er rede til å bytte med en gang jeg finner en platespiller tilkr.9.000 som spiller betydelig bedre enn CECST630 . Dette finner jeg vel ikke ut før jeg har testet 4-5 stk.antakelig her hjemme . Ikke C-Plugger men S-Plugger med Shibatanål eller H-Plugger . CEC ST 630 spiller utrolig bra .
hvalross
Er litt usikker hvilken pickup jeg skal velge av disse 2 -Tonar S-Plugger med Shibatanål eller Tonar H-Plugger med Hyper Elliptical nål . Audio Technica som har produsert disse. H-Plugger er litt rimeligere men spiller den noe dårligere enn S-Plugger . Bruker nå en AT 85 EP t4p på min CEC ST630 til kr.400 og det låter så bra .
HasseBasse
Hjortshøj, Danmark.
Rækkefølge fra nederst til øverst på ranglisten:
Bonded spherical (round).
Nude sperical (round)
Bonded elliptical.
Nude elliptical.
Bonded hyperelliptical.
Nude hyperelliptical.
Bonded shibata.
Nude shibata.
Bonded microline, fineline, microridge.
Nude microline, fineline, microridge.
Og så kommer all de ypperlige typerne som Fritz Gyger I, II &??, VdH, Pramanik, Ogura P-9 m.fl. :)
Og for at gøre det sværere, så kommer lyden også an på, hvilket materiale nålearmen er lavet af.
Aluminium rod.
Aluminium tube.
2 layer aluminium tube.
Carbon fiber.
Beryllium rod.
Beryllium tube.
Ruby rod.
Diamond rod.
Diamond tube.
Zyx sverger nu til carbon fiber.
Noen nyere fabrikanter er set bruge titanium rod & tube, noen sågar rustfri stål rod.
SoundSmith´s dyreste er med kaktusnålearm osv. osv. :)
bluesbreaker
Hundeeier
Blåskogen
Jfr trådtittel.
Ville du ha hjelp til kjøp av ny platespiller, eller vil du bare bable om CECn din?
Lykke til videre, med den.
Gjest.
Skarpe nåler ble tatt fram for å unngå problemene med forvrenging nærme innerste del av plata, da kom ellipse. Så kom 4-kanalsstereo og et behov for å spille av superhøye frekvenser pga spesiell avkoding av 4d plater. Da kom Shibata. Senere har det kommet til mye forskjellig.
Tangentialarmer ble laget for å unngå samme forvrenging. Vet ikke om slipning betyr så mye med en slik arm.
Shibata går for å være skarp og samtidig skånsom mot platene. Sliter lite pga stor anleggsflate. God gjengivelse.
hvalross
Rekner med at jeg går for S-PLUGGERN . Apropos babling om CEC n -jeg kommer nok til å sende deg mange PM er nå -Bluesbreaker -for å bable om CEC n min.🤣
Auditor
Hvalross: Mitt tips: Hent inn S-Plugger, bruk den inntil du kjenner dens styrker kontra AT. Så sammenligner du med en Pickering XV..
hvalross
Tenkte å bruke kr.9.000 på nye forskj.pickuper å prøve meg frem og så kjøpe meg ny platespiller til over kr.100.000 for å høre om det blir noe bedre lyd av en slik dyr spiller . Tror man får lik bra lyd ut av en spiller til kr. 50.000 kontra en til kr.100.000 med samme pickup og riaa . Tror forskjellene er meget -meget små -nesten ikke hørbart når prisen er såpass høy . Blir lurt til å tro at jo dyrere det er desto bedre er det.
Auditor
Hvalross: Nettopp den, ja. Kanskje ikke 9000, men prøv heller TO tusen. Som Arve sier, T4P kom litt seint. Da kan du risikere å sitte med en haug PUer du aldri får solgt igjen til respektable penger. Er lik reint tap. Match ER alfa og omega. Men det er grenser for kryssmatchpotensiale også...som jeg sa tidligere i tråden.
hvalross
Jeg skøyer bare . Er det Pickering XV15 du mener .
Auditor
Hvalross: Som sagt: Nettopp den!!
hvalross
Du tror denne pickupen spiller bedre enn Tonar S-Plugger ---H-Plugger . Hvilken lydsignatur har den . Håper den ikke har samme lydsignatur som Ortofon OM 20-30-40 .
HasseBasse
Hjortshøj, Danmark.
Igen noget vrøvl Auditor. En simpel T4P til ½" adapter, og "alle" dine T4P-pickupper vil kunne bruges i en alm., ikke alt for tung arm.
Evo III
Be Who You Are
Hjemme
Du burde lese deg opp litt på google,ikke ta alt han sier for og være fasit.
hvalross
Harfått opplyst at Pickering XSV 3000 eller høyere skal være mye bedre enn Pickering xv15 . Tror de er vanskelig å få tak i .
HasseBasse
Hjortshøj, Danmark.
XSV1200/XSV3000/XUV4500Q er alle fremragende pickupper. 1200 og 3000 med det som Pickering kaldte "Stereohedron" nåleslibning, meget nær hyperelliptic, og 4500Q kaldte de Quadrahedron, meget nær shibata :)
Auditor
Hvalross: Bruk telefonen, så finner du ut mer..Det er ikke alt som til enhver tid er ute på nettsider.
hvalross
Finner ikke annet mobilnr. enn 97162174 på Elektr.bureau i Rødhettev.1A, Kråkerøy . Stemmer dette . Rart de ikke oppgir telefonnr.på Hjemmesiden .
hvalross
Hva har det med Elektr.bureau å gjøre.:rolleyes:
hvalross
Auditor --- Har ikke fått noe svar på spørsmålet om lydsignaturen i Pickering xv15 . Ikke sikert du har hørt den .
Bartesam
Hus
En jeg kjenner solgte en slik en for 5kKr i fjor :)
hvalross
Hva har dette med saken å gjøre.-Bartis. Her gjelder T4P Pickuper .
Auditor
Hvalross: VELDIG klassisk. Kanskje litt rund på fløyene, om jeg husker. Greit varm, men fortsatt detaljert nok for det meste og de fleste. Poenget her er altså mer at du kanskje bør begynne å se grensene for kryssmatchpotensialet i CEC hvis du i det hele tatt ønsker å komme videre innen vinylen. Og bl. a. Tonar, Pickering og Grado kan hjelpe deg med det. Vær klar over at flere av Grados T4P står "US Sale Only" på på nett..Men merket forøvrig finnes i Norge også. Og ber du spesifikt OM en T4P derfra....Dog, HVORFOR skulle du egentlig det? Det ER så mye du går glipp av ved å låse deg til disse..
BKaz
Farsund
Har blinket meg ut følgende platespillere i prisklassen fra kr.5-6.000 til kr.9.000 ---- Siste modell av Rega Planar 3 ---- Teac tn 4d ---- Project x1 , debut carbon dc esprit sb , extension 10 ---- Dual cs 505-4 Sebrano Nightfall og NAD C588 . Synes det er veldig vanskelig å velge .Alle disse er vel meget gode spillere . Er det noen av disse som spessiellt utmerker seg . Erling.
*Alle* i denne tråden har mer peiling på platespillere enn meg. Jeg bruker min til å lytte på musikk med, ikke til å fikle på - for det er jeg ikke flink til.
Så ta dette for det det er verdt: Men siden man nevner både Rega Planar 3 og Mala her i tråden, minner jeg om denne som står og venter på ny eier.
Ikke for å pushe salg for noen, men som et tips til noe som kanskje kan være en bra start?
hvalross
Har sett på denne for mange dager siden . Det hjelper lite da den ikke kan sendes pga.manglende originalemballasje.
Auditor
BKaz: Og pickupen der er en 20+ år gammel konstruksjon., hvis nypris var ca. 2500 kr. I 2004. Hadde den derimot hatt en GOLDRING ELITE...med VDH-slip...
hvalross
Oslo hi fi center selger Grado Pickuper . Det finnes vel Moving Iron også i deres sortiment . Aldri hørt Moving Iron Pickuper -har du Auditor.
