PS Audio
  • Supersound
    Tror nok den nye P10 blir bra. Den blir bygget på samme lest som P20.
    Men å sette en skilletrafo foran kan vise seg å være feil i følge PS Audio. Jeg spurte dem direkte på det og fikk følgende svar:
    «We discourage the use of any other power conditioning equipment before or after the P20 without considerable evaluation. A critical determination will have to be made as to whether there are any sonic or visual shortcomings. The P20 has a significant input & output passive filter design and adding extra power cables to its input or additional filtering to its output may, in fact, be undesirable.”
    Dette gjelder P20 men jeg kan ikke tenke meg at det blir noe forskjell på den nye P10.
    Men det finnes kanskje andre måter å fjerne støy over 1kHz? Uten at det går utover strømmen til P20? Noen som har ideer?
    Papillon
    Vestfold
    Andre steder på PS Audio forumet har jeg sett Paul snakker litt anderledes om ytterligere støyfjerning sammen med P10 (mulig at noe av det som Paul sier nedenfor bare gjelder gammel type P10):
    https://forum.psaudio.com/t/noise-harvester-and-my-p10/5231
    På spørsmål om å sette en NoiseHarvester på samme kurs svarer Paul:
    "It’s the same as the HumBuster we used to make. The circuit to that 's pretty simple, two full bridge rectifiers in series with the line and a handful of capacitors to smooth the transition. This will remove up to about half a volt of DC and is quite effective. Power Plants already block DC but they themselves are susceptible to it. By that I mean if there’s enough DC to make a power transformer hum, then the power transformer on the Power Plant might hum - which this thing will help. But, in any case, Power Plants block DC from getting to your equipment."
    "The Harvesters look at a fairly specific and narrow band of noise frequency, around 10kHz which the P10 does not address. We chose the 10kHz region for the Harvesters to work on and they do help if in front of a P10, not at its output. The unfortunate truth is that once the P10 regenerates new AC its lower output impedance won’t allow the Harvester to do its work. On the input to the P10 it’ll help reduce that area. Power Plants focus on about 1kHz down."
    https://forum.psaudio.com/t/clean-wave/4655/10 :
    "By degaussing the transformer it helps not only the sound but, as you have seen, it can demagnetize the lams so they don’t buzz from DC."
    I denne tråden (https://forum.psaudio.com/t/powerplants-and-intra-component-noise/5212) på PS Audio forumet, så innledes det med et spørsmål om hvordan P20 hindrer en komponent i å påvirke andre komponenter med støy. 2 poster fra Paul gjengitt nedenfor.
    "Indeed and this is actually a big deal. After all, we can’t afford a P20 for each piece of kit that needs powering! Injected noise from connected equipment is real. Fortunately we have solved this problem, or at least mitigated it to satisfaction, by several means. The way we built the P20 internal power delivery system and the low output impedance of the P20. Internal to the P20 is a series of gold plated thick copper buss bars connecting the AC receptacles together. This means there’s nearly nothing standing between the regenerator’s output and the receptacles delivering the power. The next thing, and this is the most important, is the output impedance. Because we design around a Class AB amplifier, while other regenerators tend to be Class D, we have the advantage of huge peak current delivery and extraordinarily low output impedance. This means that connected equipment cannot generate a noise voltage across the receptacle, thus isolating products connected to the P20."
    "Yes, you’re right, we had Isozones back then because we hadn’t yet figured out how to isolate one receptacle from another. In a modern P20 that’s all changed. Because of the wiring, now consisting on 1/4” thick gold plated copper bars, and the magnitude lower output impedance of the regenerator, it is no longer possible for attached equipment to place noise onto the Power Plant’s output. So noise from one receptacle is isolated from any other."
    ymir
    Dersom jeg ikke missforstår så er fokus på PS regeneratorer på område fra 2nd harmoniske
    og opp til 20nd harmoniske (1 kHz).
    Dersom det er riktig ser jeg da grunnen til at min PS Audio regenerator var til ingen hjelp.
    Utstyret ellers taklet fint THD langt over 8% og 5 harmoniske over grenseverdi på 6%.
    Problemet elektronikken ikke takler ligger utenfor forskriften for harmoniske som er 2500Hz,50nd harmoniske.
    Nylig måling viser dessuten at Noise Harvester forsterket problemområdet rundt 5 kHz på nettet.
    Papillon
    Vestfold
    Veldig interessant. Takker for det innlegget! Hvordan/med hva målte du THD til 8% og 6% ?
    Og ørene dine og du synes det var greit, altså?
    ymir
    Målingene var fra netteier.Vi var i "øydrift" nesten daglig i ett års tid.
    Og ørene syntes det gikk greit.Kun en beskjeden temp. økning på elektronikken.
    Hadde nylig en fra netteier på besøk,han hadde min klagesak mht spenningskvalitet.
    Han ser også nå at problemet høyst sannsynlig lå utenfor forskriften,dvs fra 2500 Hz og oppover.
    Vi leitet i feil ende av skalaen,det eneste avviket som er deres (netteiers) ansvarsområde,
    fant han ved 1150Hz.I praksis ubetydelig for lyden.
    Han har funnet resonanser ved 4.5kHz,7kHz og 10.5kHz,og da han var på besøk nå nylig
    måltes tydelig en forsterkning ved rundt 5kHz når emi/rfi filteret og Noise Harvester var innkoblet.
    Helt etter hva som skjedde med lyden.Sluttningen ble at jo høyere orden harmoniske,
    jo større problem for elektronikken,dvs godt over 2500kHz.Også for regeneratoren.
    Papillon
    Vestfold
    Hmmm...tror jeg må konsentrere meg om å høre musikk nå. Blir veldig mye detaljer å grave seg ned i med denne strøm-problematikken. Har latt DMP/DSDAC kjøre forskjellige SACD'er på repeat i noen døgn nå - skal nyte musikk i påsken.
    God påske!
    DPH
    Hei,
    Noen her som har erfaring med PS NuWave Phono Converter, som kunne dele litt erfaring/synspunkter om den i forhold til bruk som en phono forsterker?
    Er på sjakt etter ny platespiller, og har sett en god del på NPC, da det ser både ut som en får en god phono forsterker, samt ADC delen.
    Drossel
    Yes så har jeg bestilt et Ps Audio drev. Så nu kan jeg snart overføre I2s via Hdmi til Ps Audio Dacen. Kæft jeg glæder mig.
    Distinctive
    Å vente på noe nytt som er på vei, koble det opp og lytte på resultatet er jo halve hobbyen.
    Men dette møter nok liten forståelse hos den gemene HFS hopen for her teller jo bare den rasjonelle oppfatningen rundt kroneverdien.....
    H
    hifierik
    Spännande, kan du förklara mer vad du tänker göra? Förlåt men vad är PS Audio "drev"?
    taffern
    Hei,
    Er også interessert i andres erfaringer/synspunkter med NuWave Phono Converter. Fint om noen ville delt info med seg :)
    Papillon
    Vestfold
    Sitter her og hører på Beethovens 7nde og titter bort på APL Dac'en etter å ha lest Rognliens artikkel. Har dessverre ikke drivverk med i2s til den, så en sammenligning må skje med coax.... Nei, jeg hører videre med DS'en. Takker og bukker!
    Drossel
    Kan sige Den danske anmelder Jan Nielsen netop har kjøpt en Ps DIrect stream dac. Min model er ikke den sidst ankomne.
    Distinctive
    Er det en PerfectWave MKII DAC du har?
    Er ikke det samme nei, men den låter ‘innsmigrende’ nok den selv om den ikke når opp samme liga.
    Fint second hand kjøp, dog.
    Drossel
    Den er købt som ny og derfor ikke second hand.
    Distinctive
    Ok.
    PS:
    Er ikke opplagt for meg hvem denne Jan Nielsen er......(?)
    Har du en link til omtale?
    Drossel
    Hmm skuffet over værket. Det har stået ubrugt en uge ca. Prøvede her til aften. Hos mig er OPPO 103 EU Coris moddet mye bedre i selskab med det andet. Prøver nok enten å sælge det eller å få Importøren til å tage det tilbage.
    Distinctive
    Har du oppdatert firmware i PWD’en?
    Koblet du drevet til DAC via I2s?
    Har EC som bruker Oppo drev.
    For meg høres noe riv ruskende galt ut hvis Oppo banker dette settet.....
    Drossel
    Dette er en moddet Oppo med Coris lineær forsyning , Clock til proccesoren og fjernet analogdel. Banker et ordinert Oppo noget så eftertrykkeligt.Nej jeg har ikke opgraderet firmware. Går ud fra det er gjort når den kommer direkte fra importøren som har brugt det som demo. Jeg spørger ham senere idag. Tak for tip. Tak for link.
    Er det ingen mulighet å tappe i2s fra oppo drevet ditt?
    Drossel
    Jo men kender ikke hvordan det er forbundet inde i Ps. Det er ikke standard
    Standard og standard. i2s er en standard men siden de bruker eksterne drev og da trenger lengre kabelstrekk bl.a. så bruker de en "balansert" versjon kalt "lvds" og hdmi som interface. Ikke noe hokus pokus og pinout er åpent og dukumentert. Om du kan tappe sdata, lrck, bclk, (kanskje også dsd?) fra oppo drevet ditt så har jeg pcber som gjør om standard i2s til "ps audio standard" i2s(lvds).. Just saying. Da kan du overføre i2s over hdmi kabel...
    Evo III
    Hertugen av Langhus
    Hjemme
    Fått inn mere PS Audio.
    BHK Pre-Amp og Directstream dac,låter bra dette men det trenger noen timer før rørene spiller opptimalt tenker jeg.
    Fint å spare en box pluss kabler med streamer i dac.
    Drossel
    Jeg kan sagtens finde det i Oppoen. Værre er det hvordan det er i PS Audioen.
    Drossel
    Men Oppoen er nu dømt ude. Ps Audio er milevidt bedre med optical end Oppoen. Konklusion det Hdmi jeg brugte igår er crap.
    Håkon_Rognlien
    Jeg undrer meg fortsatt over dette her. Hos meg (som er relativt forsiktig med å hevde at det er store forskjeller på drivverk), viste da virkelig PS-drivverket seg som noe for seg selv. Og spesielt med I2S gjennom HDMI, der toppen av kransekaka kom med gode SACD-skiver i skuffen.
    Ikke gi opp, jeg tror du har mer å hente.
    Håkon Rognlien
    Drossel
    Desværre er dette værk ikke til Sacd. Men fuck det spiller fantastisk nu.Sikke en forvandling fra igår til idag. Fantastisk hobby det her.
