Yamaha NS 1000 M
  • Tønnes
    Flekkefjord
    Ja da var Yamaha NS 1000 M rengjort og godt over .Det var meget med skitt på disse .Så det en del vasking før di ble rene .Jeg måtte spraye front bryter ,som skurret litt når jeg vridde på dem,men jeg bruke noe el spray ,og det ble helt tyst med knittring.Så testa jeg dem med litt musikk og det hørtes meget godt ut dette .Men fant da ut at disse er ikke bare Yamaha NS 1000 ,men og en M bak 1000 ,så den m er jeg ikke helt sikker på hva er da,men det kan vell andre si meg her inne på sentrallen.litt bilder fra værkstedet som di står og blir godt over nå .;)
    MVH:Tønnes
    TT.
    The smooth jazz guy! 😉🇳🇴
    Knapstad
    M står rett og slett for Monitor
    The Last One
    Trondheim.
    2000 kr, røverkjøp :)
    "The end of the weak link
    - or so Yamaha stated in 1974.
    A real statement loudspeaker at any rate, part of the NS Series, Yamaha's top-end audio production, still on today even if with less ambitious... goals. NS stands for Natural Sound and the M in NS-1000M stands for Monitor,maturally.
    The stars of the 1000M show are the Berylliumdomes, here made with a process not so distant from the one used for the V-FET transistors from Yamaha... and Sony : vapor deposition in vacuum on a pre-shaped copper mold.
    For audio uses, Beryllium is better than aluminum, titanium, magnesium or whatever-um (not to mention soft domes).
    Yamaha's ultimate (literally) GF-1 monster and Sony's more discrete but excellent SS-A5 Bio-Cellulose were yet to come, but that is another story.
    The NS-1000 is the "home" version, adorned with a lavish polyurethane coated ebony finish ; not a veneer add-on, mind you, but real solid thick wood !
    Apart from this 8kg surplus of good looks (1000) and the protection on the woofer (1000M), both versions are identical.
    The pre-production samples were named NS-1000X (capital "X", until august 1974), the NS-1000M saw an upgraded NS-2000 version, a later NS-1000x (1984 - more of an upgraded NS-1000M) and an ultimate version in the NSX-10000, produced in small quantities for Yamaha's 1987 Centennial anniversary.
    More recently, JM Lab, french manufacturer of grand designs as the Grand Utopia, broughtBeryllium center stage again for a line of professional monitoring loudspeakers.?
    Unlike most audio masterpieces, there are thousands and thousands and thousands and thousands of NS-1000 pairs around the world so catching a pair isn't difficult at all.
    Spare beryllium domes, however, while still available until about 2006, are now (2009) all gone.
    The NS-1000M and NS-1000 are acoustic suspension designs and were delivered as matched pairs but it is true they need very careful matching with amplifiers and sources : avoid all that makes fizz and slash and zing for they do have a slight tendency to bring a bit forward mid and high-mid frequencies. Try a Luxman L-540 for instance.
    Two zeros below, the 1977 NS-10M distant cousin (sans Be drivers) graced many a recording studio throughout the 1980s and 1990s - with lots of us tweaking 'em to death to bring this little thing to the limit.
    Yamaha made a gazillion lookalikes of the NS-10M and a hundred versions and variants of the NS-1000, with or without Be domes, to cash in on the NS-1000 craze, sales and following. It worked : even today, a white pulp bass driver is likely to be immediately recognized as Yamaha's and Beryllium is Yamaha.
    Yamaha NS-1000 on thevintageknob.org
    TT.
    Knapstad
    Bare hyggelig The Last One. Google er fint ;)
    Tønnes
    Flekkefjord
    Ja da fikk vi noe nytt om Yamaha NS 1000M igjen.Ja da blir disse restaurert av meg nå i vinter,jeg må nok lakke dem i pianolakk .Camilla vill ha disse i den nya stua som sikkert kommer om ikke så lenge
    MVH:Tønnes
    Johannesen
    stavanger
    men uten om m for monitor i navnet,er det annen forsjell på home version og monitor version da?? litt rart og kalle en høytaler for 2 ting hvis det er samme høytaler...forsjell på delefilter,ohm,etc???
    Tønnes
    Flekkefjord
    Disse skall være helt like etter det jeg har funne ,men da utenom at di home versjonen er i tree sorten ,ellers skall di være helt like ?? jo ok men e det alt bare ??
    MVH:Tønnes
    Tønnes
    Flekkefjord
    Hmm så nå at di er 8 ohm ,mens ns 2000 har 6 viss jeg ikke så helt feil ,der e nok delefilter litt annerledes da .?
    MVH:Tønnes
    K
    Kleine Freiheit
    Sitat fra TVK.
    Tønnes
    Flekkefjord
    Hei jeg prøver og finne ut hva type farge ( lakk) han bruker på disse wooferene til Yamaha NS1000 som jeg nå resturerer.Hva han bruker på pappen er jeg ikke sikker på men viss noen har hva jeg skall bruke hadde det våre fint om noe kan fortelle meg det.Her er en youtube klipp.
    https://www.youtube.com/watch?v=wtwWMYzainA
    MVH:Tønnes
    tigerw97
    La den ut fordi noe lurte på hva forskjellen på NS-1000m og NS-1000 var. Før NS-1000m ble lansert fantes det en prototype som het NS-1000x, etter NS-1000m, NS1000 kom det også en modell som het NS-1000x som hadde basselement i karbon. En enda mer påkostet utgave het NS-1000xw.
    Membran laget av papir blir tilsatt en coating for at ikke papiret skal trekke til seg fuktighet, hva som benyttes av coating er nok litt forskjellig fra fabrikat til fabrikat. Tror nok ikke du skal bør lakke disse på noen måte.
    Tønnes
    Flekkefjord
    Ja da var Yamaha NS 1000 ribbet til skinnet og pusset godt ned,noe hakker var det og se på veien ,men lite en ventet da.Så litt sparkel men så lite at det kun blir en liten klatt til sparkel da.Som dere kan se så er di pussa helt til skinnet .Blir og lakka noe forsterker fronter til Roger J som og skall ha sort farge i samme rennet .
    MVH:Tønnes
    Tønnes
    Flekkefjord
    Da var det farge på elementa og fått ut noen bulker på gitter og fått sett over at disse er 100% tipp topp stand,og det er det,usedvanlig bra stand for og ha disse åra på seg,så det viser seg at di har tatt godt vare på disse .
    ;) MVH:Tønnes
    Tønnes
    Flekkefjord
    Wow. Blir pent dette!
    Hei Stig ,ja jeg tror disse kommer til og bli meget pene når jeg har fått pianolakk på med klarlakk ,som jeg og vill mellom slipe og føre på enda mer klarlakk,og så komme høyglans polering etter på :) .Jeg har fått sett godt over dem og ja di ser bra ut.
    MVH:Tønnes
    Hb 52
    Flott tråd Tønnes !!
    Virkelig flott arbeid du gjør !!! Arig å se at folk kan sitt håndarbeid !
    Hb 52
    Tønnes
    Flekkefjord
    Hb 52
    Takker for det Hb 52 ,så får vi se når lakken er kommet på og di har fått inn elementa i kassene sine.Men nå blir det litt lakking i rom jula ;) .
    MVH:Tønnes
    Hb 52
    Hb 52
    MVH:Tønnes
    Blir spennende å følge !!!
    Tønnes
    Flekkefjord
    Imponerende bra jobb Tønnes. Norges svar på KENRICKSOUND du :cool:
    Takk for komplemanget Whiplash ,jeg gjør så godt jeg kan ,og er spent på resultatet.Jeg har nå fått på grunning i går ,og pusser ned i dag for og så se over om det blir lakk på i dag .
    MVH:Tønnes :)
    Whiplash
    Jobber du som bil lakkerer ? Prikken over i'en var farging av elementene. Detaljene teller.
    FeitArne
    Dette blir knall bra! Mye jobb når man er grundig.... Jeg har 3 par, tar du de i samme slengen? :)
