NORDOST PATENTS........
W
WayAhead
De skal nå ha for at de tross alt har lagt en del jobb i dette og i disse dokumentene beskrives konstruksjon og formål nokså detaljert.
I det minste ser man hva intensjoner, konstruksjon og løsninger de har utviklet.
Det kan finnes flere patenter fra NORDOST men festet meg ved disse.
Fra Google Patents - bilder og diagrammer på de aktuelle sidene:
Audio loudspeaker cable assembly
https://patents.google.com/patent/US5510578A/en?q=nordost
A cable assembly for connection between an audio amplifier and a loudspeaker in which a plurality of insulated electrical signal-conducting wires, or conductors are bundled together. The conductors are formed into two groups, one of which is connected between the positive terminals of the amplifier and the loudspeaker and the other of which is connected between the negative terminals of the amplifier and loudspeaker. The number of conductors and the diameter of each conductor is chosen and the design is such that the characteristic impedance of the cable assembly is within the range of the impedance of the loudspeaker. As a result a significant reduction in ringing and/or blurring of complex musical transient signals caused by reflections attributable to the mismatch between the characteristic impedance of the cable and the input impedance of the loudspeaker is achieved.
Audiophile cable transferring power substantially free from phase delays
https://patents.google.com/patent/US5110999A/en?q=nordost
Abstract
The invention provides a compact, circular, flexible, and shielded twin-axial, multi-stranded power cable for transferring current instantaneously and with uniform density substantially free from phase delays at 60 Hz. between a high current power amplifier and a standard three-hole 112 volt AC outlet achieving a pure and powerful bass response and clear, brilliant noise-free highs. The cable has two bundles of five insulated conductors helically and symmetrically wrapped around a dielectric center. The gauge of each conductor and total cross-sectional area of the bundled conductors are predetermined to avoid internal inductance and phase delay effects while providing high current instantaneously and uniformly in high-end audio power applications. In between the bundles are located ground wires which run the length of the cable. The bundles and ground wires are spirally twisted around each other for structural integrity and for a generally round cross-sectional shape. A thin polypropylene filler surrounds this spiral twist. A non-insulated drain wire and an aluminum foil shield are wrapped around the filler. A flexible cable jacket is extruded around the shielded cable. The cable of the present invention unexpectedly renders benefits in high-end audio applications even though it does not operate within the signal path of the system.
Stranded conductor and its manufacturing process
https://patents.google.com/patent/RU2242061C2/en?q=nordost
Abstract
FIELD: electrical engineering.
SUBSTANCE: proposed stranded conductor designed for signal transfer in audio frequency band from readers to amplifying and/or reproducing domestic and professional devices is manufactured in process involving production of flat metal strands and coating of stranded conductor surface with insulation. For the purpose use is made of at least three flat metal strands, and additional insulating layer is disposed between flat surfaces of adjacent strands prior to coating stranded conductor surface with insulation; end sections of strands are brought out beyond insulation layers and strands are interconnected at each end section of conductor; the latter is made of at least three flat metal strands 11, 12, 13 whose flat surfaces are facing each other with insulating layers 9 and 11 inserted between flat surfaces 5-6 and 7-8 of adjacent strands 1-2 and 2-3; end sections 11, 12, and 13 of strands 1-3 brought out beyond insulating layers 4 and 9-10 are interconnected through solder layers 14 and 15.
EFFECT: reduced distortion of electric signal in audio frequency band when passed through proposed stranded conductor.
3 cl, 4 dwg, 1 tbl, 5 ex
W
WayAhead
Greit å få litt sakelig info fra den andre siden kanskje, ikke bare ensidig trashing eller hva?
Forøvrig interessant lesing.
DagT
Det fine med de patentene du viser til er at de har gått ut på dato eller, i det siste tilfelle, bare gjelder i Russland. Dermed kan enhver DYI eller konkurrent lage dem og prøve det ut. Hvis ingen har gjort det kan ikke ideen ha vært så voldsomt interessant.
Dessuten er det jo sånn at et patent ikke er noen garanti for at det virker (selv om det formelt sett er et krav), bare at det var nytt da de søkte om det.
W
WayAhead
Det mest interessante er vel beskrivelsen av konstruksjonen og formålet. Når det gjelder resultatet er vel "satiskaction not guaranteed"
Imagine
osøyro
Enda en kabel tråd :mad: Nå får moderatorer slette over halvparten av trådene her inne , dere som starter dette er dere på fylla eller.
Imagine
W
WayAhead
Avfei før les? Det er kanskje vanlig metode for de fleste her på sentralen?
Bergfinn
I dette øyeblikk ligger det 5 kabeltråder etter hverandre.
Nesten så jeg får lyst å logge av HFS for godt, i protest.
Meg om det, og det blir kun mitt tap. Sikkert flere som holder tommelen opp for å bli kvitt enda en kabelskeptiker.
Imagine
osøyro
Nesten så jeg får lyst å logge av HFS for godt i protest.
+1
Imagine
Hehe... fem på rad var MIN måte å "protestere" på, sette fokus på galskapen om du vil. Men det hjelper nok ikke! Folk elsker å pisse på maurtuer.
W
WayAhead
Denne kommer til å dale da det ikke er stort å diskutere annet enn at innlegg som dine kan holde liv i den.
Dette var ment som ren informasjon fra min side - ikke å starte en ny "flame tread".
Forøvrig skjønner jeg ikke hva problemet er. Det går vel an å velge bort enkelte tråder - gjøre de usynlige på dette forumet som andre - ikke sjekket men dere er kanskje for nysgjerrige likevel til å velge en slik løsning?
OPPDATERT: Nå er det U NAY SAYERS som sørger for at den topper...
DagT
Jada, men husk at patentteksten har som funksjon å overbevise en saksbehandler (og evt en dommer) om at dette er smart. Noen prøver å løse det med tåkeprat og andre med store ord. Dermed ligger de litt på kanten av hva de kan stå inne for selv om de gjerne luker vekk det verste tullet (ref til kvantemekanikk o.l.). Noen ganger kan det være ganske fornøyelig å lese saksbehandlingen, ihvertfall når saksbehandleren skjønner tegninga og påpeker at beskrivelsen ikke er god nok til å fortelle hvordan de får til det de lover.
DagT
Og forresten: Jeg er litt usikker på hvorfor de dukker opp når du søker på NordOst, for det er ikke de som eier/eide disse patentene. Mulig det har noe med Google databasen å gjøre, for jeg bruker vanligvis ikke den.
Hardingfele
Forumet er i ferd med å bli et kabelvillniss. Hva med å diskutere kilder, høyttalere og lytterom med samme energi? Der er det faktisk forskjeller, og disse kan ofte oppnås med ganske enkle midler.
Spaghetti er ikke hva hobbyen handler om.
Z
Zomby_Woof
Kabeltrådene er egentlig forkledde diskusjoner om tillit til bransjeaktører generelt. Sånn sett er det interessant nok, men det er en stedfortreder for den diskusjonen vi egentlig burde hatt, og det er kanskje grunnen til at alle hjul spinner i løse lufta.
Siden det har vært litt skrifting i det siste. Jeg har også trodd på kabler, villet høre, og hørt. Så ble jeg oppmerksom på at dette er kontroversielt, og dermed kunne jeg begynne å stole på mine egne ører.
Mange takk, ingen nevnt og ingen glemt.
Distinctive
Kabeltråder eksisterer også for å pleie ens eget ego mhp. både egen overbevisning, egen kompetanse og eget ærekjære ståsted. Derfor blir frontene så steile.
Som DagT også påpeker: Ingen av de siterte patentene har Nordost Corp som assignee. Den eneste koblingen jeg ser er at den russiske patenten sammenligner sin løsning med en stump Nordost-kabel:
For comparison, under the same conditions as the bonding wire was taken known flat wire marks Blue Heaven Rev.2 NORDOST manufactured (see., E.g., catalog NORDOST CORPORATION, 420 Franklin ST., Framingham, MA 01702, USA).
De andre to patentene ser ikke engang ut til å nevne Nordost, så det er ikke klart for meg hvorfor de dukker opp i dette søket. Det er definitivt ikke "Nordosts patenter" på noen måte.
Når jeg søker på "Assignee: Nordost" direkte hos USPTO finner jeg bare en designpatent (mønsterbeskyttelse) D747,641 for en "vibration damper" datert 19 januar 2016. Det eneste det kreves patent på er det kosmetiske utseendet av dingsen:
CLAIM We claim the ornamental design for a vibration damper, as shown and described.
Om designpatenter:
https://en.m.wikipedia.org/wiki/Design_patent
In the United States, a design patent is a form of legal protection granted to the ornamental design of a functional item. Design patents are a type of industrial design right. Ornamental designs of jewelry, furniture, beverage containers (Fig. 1) and computer icons are examples of objects that are covered by design patents.
Hvis jeg søker på "Inventor: Joseph Reynolds" får jeg opp noen fler patenter, men de er fra andre personer med samme navn og gjelder sånt som kollisjonsbeskyttelse i biler. Igjen er denne ene mønsterbeskyttelsen eneste "patent" fra "vår" Joe Reynolds i Framingham, MA.
Min konklusjon er at den eneste "patenterte" teknologien Nordost Corp faktisk har rettigheter til er dette ene mønsterbeskyttede utseendet for en vibrasjonsdemper. De har ingen patentert teknologi for kabler, uansett hva de selv liker å hevde i reklamen. Ingen.
Jeg kan ikke si at jeg er overrasket, men jeg kan heller ikke si at jeg fikk særlig mer respekt for sjarlatanene etter å ha sjekket dette.
Z
Zomby_Woof
Kabeltråder eksisterer også for å pleie ens eget ego mhp. både egen overbevisning, egen kompetanse og egen ærgjerrighet.
Det har du nok helt rett i. Egoene som brynes mot hverandre er 'jeg hører bedre enn dere' og 'jeg tenker bedre enn dere'. Det ene like uspiselig som det andre, strengt tatt.
Zerostat
Lillestrøm
Noen av de beste trådene her inne er kabeltråder. Dem er lærerike i alle rettinger. Spesielt lærerike er dem som kommenter andres meldinger som piss.
DagT
Ulempen med databasen til USPTO er at de patentsøknadene ikke ligger der, men i en egen database. Den Europeiske er på den måten bedre, og derfra kan jeg bringe den gledelige nyheten at de relativt nylig (2013) har levert inn en patentsøknad på en Phono Connector. Riktignok ikke mye kvantemekanisk nanoteknologi, og ikke ser det ut til at de får patent (de har gitt opp i USA og Europa), men rett skal være rett...
https://worldwide.espacenet.com/pub...T=D&date=20160107&CC=US&NR=2016006144A1&KC=A1
Aurora
Ytterst i havgapet...
Skulle nå faen bare mangel omde skulle klare å få patent på en phonoplugg,- bare i junaiten at slikt går an... enda hyggeligere at det ble et avslag...
whistler
Det er vel dette patentforsøket som har blitt til den nye HOLO-pluggen som benyttes på Odin2.
Aurora
Utgangspunktet for ethvert patent er at "noe" ikke finnes fra før - det skal være noe nytt, en ny metode etc etc. Man kan derimot får copyright på et spesielt utseende eller en møsnterbeskyttelse for et utseende ller en bestemt måte å lage noe på...
Z
Zomby_Woof
Apropos NASA og kabler:
https://www.popsci.com/scitech/article/2007-07/nasas-19-million-toilet
Og dette fører oss tilbake til HF-/VHF-/UHF-relevant kabelproblematikk, tatt til inntekt for designløsninger for audiofrekvenser. Greit nok at dassen til NASA er dyr, men man kan altså drite i vektløs tilstand med hygienisk akseptabelt resultat på den. Hjemme, med 1G i noenlunde forutsigbar retning, så holder det med en sånn:
https://coop.no/sortiment/obs-bygg/...MIhPv46fn81gIVQZSyCh1sDgqoEAQYASABEgIO0PD_BwE
