Hei!
Tenkte jeg måtte dele dette på forumet.
Jeg har hele tiden tenkt at når jeg streamer fra iPad/andre Apple produkter så skjer dette alltid via produktet man streamer fra. Med ulemper som redusert batterilevetid. Dette blir brukt som salgsargument for de som selger produkter med Spotify Connect, og jeg lurte derfor på om jeg skulle teste f.eks nye Stream Argon boksen til
HiFi Klubben. Men som storbruker av Spotify, synes jeg ikke batteriet i min iPad blir nevneverdig redusert.
Prøvde å finne ut av dette og fant:How Apple AirPlay & AirPlay Mirroring works - FlatpanelsHD
Etter det jeg skjønner, har jeg og mange andre lite igjen for å investere i Spotify Connect produkter?
Let us start with music and video that is stored locally on an iOS device. Music is streamed in the Apple Lossless format at 44100 Hz in up to 2 stereo channels (no surround support so far). In other words without loss of quality. Video streaming utilizes the H.264 mpeg format without compression (except the compression in the actual video file). The video file needs to be transferred into the Apple TV cache before the video file plays and therefore you will experience some waiting time. The faster wireless network you have, the less waiting time. Again, remember that we are talking about locally stored media files here.
AIRPLAY STREAMS IN LOSSLESS FORMAT, AND WHEN WATCHING OR LISTENING TO ONLINE MEDIA A DIRECT CONNECTION TO THE INTERNET SOURCE IS OPENED TO AVOID CONVERSION
When using internet sources for watching video (such as YouTube) or listening to music (such as Pandora, Spotify or any internet radio service) something else happens when using AirPlay. When streaming from an internet source and pressing the AirPlay button on your iOS device, your AirPlay-enabled music system or Apple TV box will open a direct connection to the internet source. The AirPlay receiver (for example Apple TV, AirPort Express, or systems with built-in AirPlay) is being authorized to access the internet source and no streaming occurs between the iOS device and the AirPlay receiver, thus no loss of quality. The video or music quality is as good as the streaming service allows.
