Kalibreringspakke for platespilleroppsett.
Kun via Endpoint Audio og godkjente forhandlere.
Acoustical Systems leverer allerede markedets mest nøyaktige protraktor for å sette opp din platespiller perfekt. Sammen med Analogmagik og Acoustical Systems har du nå muligheten til å fintune hele oppsettet og få analoglyden så perfekt som det lar seg gjøre.
Analogmagik leverer en pakke med programvare og testplater som lar deg måle alle parametre i prosessen.
vi har 3 kalibreringspakker hvor vi har satt sammen Analogmagik + Acoustical Systems sine løsninger!
Pakke 1:
Acoustical Systems Smartractor (4995,-) + Smartstylus (1195,-) + USB Lydkort anbefalt av Analogmagik (1300,-) + Analogmagik All In One Cartridge Setup Software & Test LPs. 7500,-
Totalpris for alle deler 14.990,-
Pakkepris 13.000,-
Pakke 2:
Acoustical Systems Smartractor (4995,-) + Analogmagik All In One Cartridge Setup Software & Test LPs. 7500,-
Totalpris for alle deler 12.495,-
Pakkepris 11.200,-
Pakke 3:
Totalpris 8.800,-
Pakkepris 8000,-
What is AnalogMagik ?
AnalogMagik is a Windows based turntable cartridge calibration software designed by Richard H. Mak and a team of engineers. It offers a scientific and repeatable method of calibrating every cartridge setup parameter, including:
Turntable Speed
Azimuth
Vertical Tracking Angle / Stylus Raking Angle
Anti-Skating
Optimizing Phono Stage Loading
Optimizing Phono Stage Gain Setting
Vertical Tracking Force
Measuring Vibrations
Determining Resonance Frequencies
AES Wow & Flutter
After you have performed a basic alignment on your turntable's cartridge using an appropriate alignment tractor, our software and Test LPs will help you optimize and fine-tune all the above setup parameters to achieve a more accurate analog cartridge setup.
Simply follow the onscreen instructions, and the program will guide you through all the test functions. It will also tell you what "optimal" numbers to look for, and what cartridge adjustments you need to make to get there.
https://youtu.be/O1CBS5CfRtI
Sjekk ut https://www.analogmagik.com/ og alle tutorials på siden for å få et bilde av hva dette er.
Her ser vi tydelig hvor nøyaktig Acoustical Systems protraktor er!
Tom Egil
vidarje
Rasta
Dette burde være standardutstyr for alle med skikkelige platespillere. Er det stor forskjell i lyden hvis spilleren er satt opp med dette versus en vanlig god protractor og bruk av øret? Artige og lærerike videoer på hjemmesiden til AnalogMagik.
motoren
Flekkefjord
Sikkert gode greier og det kunne jo være greit å ha men synes det var en stiv pris? :)
Hver sin lyst
Peringolf
Fersking
Har klart meg med en Rega protractor i mange år.+øyne, ører og en nøyaktig "linjal"
Endpoint Audio
Tønsberg
Endpoint Audio
Endpoint Audio sine annonser
Godt Nytt År!
Godt Nytt År!
2025 – Et fantastisk år for analog lyd hos Endpoint Audio 2025 ble et virkelig eksepsjonelt år for Endpoint Audio. Jeg opplevde et rekordår i salg av analogt utstyr – platespillere, pickuper...
Black Friday tilbud hos Endpoint.
Vi kjører Black Friday tilbud, og ønsker å fremheve spesielt varer fra Canor! -15 % på Performance og Premium Line, samt hele 20 % på Reference Line. Tilbudet gjelder fra i dag og frem til 14...
Canor A3 integrert alt-i-ett forsterker imponerer!
  • 1
Canor har siden lanseringen fått en rekke gode tester som samsvarer veldig godt med mine egne opplevelser - fantastisk lyd i en liten pakke for deg som ønsker et enklere oppsett uten en masse...
Lockwood Loudspeakers - Endpoint Audio
  • 12
Endpoint Audio presenterer: Lockwood Loudspeakers – Et legendarisk britisk merke gjenfødt for ekte audiophile. For halvannet år siden – i mai 2024 – sto vi klare til å lansere Lockwood...
J.Sikora Aspire.
J.Sikora Aspire.
  • 2
Nyhet: J. Sikora Aspire – Den nye inngangsporten til high-end vinyllyd! Vi har spennende nyheter fra den polske high-end produsenten J. Sikora. Selskapet, grunnlagt av Janusz Sikora, har...
Lampizator Aphrodite - Lampizators nye flaggskip.
  • 5
Lampizator fortsetter å pushe grenser og jobber hele tiden med å sette en ny standard for industrien. Lampizator leverer DAC’er fra 65.000,- og oppover. Av alt jeg har hatt så er det lite som...
