Furutech - SK-EX-III Static remover
Furutech har et kontinuerlig sterkt fokus på elementer som skaper problemer for vår avspilling av musikk
Denne gang er det en spesialsak for fjerning av statisk elektrisitet på LP plater og CD plater. Kan også brukes til kabler og annet..
SK-EX-III
Ser ut som en liten mappe eller en lap-top
Åpne lokket og legg platen ( platene ) inni og lukk igjen og la platen( platene ) ligge der i ca 30 sekunder
Åpne lokket og trykk med fingeren på en jordingsknapp
Det er det hele!
For mer info: PM Audio
Pris: kr 5790,-
Ta kontakt på:
e-post: pmaudio@online.no
Tlf.: 38 18 31 15
Furutech Select Series
SK-EX-III Disc Static Eliminator
The SK‐EX‐III is the latest extremely effective disc treatment brought to you in the Furutech Select Series.
Simple fact: as LPs and CDs spin, friction with the air causes them to constantly gain a static charge ‐ frictional
static electricity for LPs and CDs can be as much as 3,000~20,000V. The SK‐EX‐III puts an end to the problem of
electro static noise and deteriorating sound quality for good by eliminating the floating static charge around
your disc media
By simply placing your disc media into SK‐EX‐III and closing the top for a mere 30 seconds, static charge will be
dissipated into the atmosphere. The SK‐EX‐III does this using 100% Thunderon®‐ a unique conductive filament
material that consists of a very fine acrylic fiber chemically bonded with copper sulfide. The exact combination
of Thunderon Sheet®material and Thunderon Tape®‐ formed of these special fibers ‐ has been exhaustively
tested to find the perfect balance for optimum static elimination. The SK‐EX‐III is easy to use, requires no
batteries or mains power and is the perfect complement to your disc media and for your listening pleasure.
Instructions:
1. Lay the SK‐EX‐III on a flat surface
2. Open the lid and place LP or CDs on circle area –CDs should be placed on the “”Thunderon Tape®3. Close Lid for 30 seconds
4. Open lid and touch the metal clasp (shown below: base of “”Thunderon Tape® with your bare finger –this will ground the SK‐EX‐III.
5. Static elimination complete. Remove your LP or CDs.
* Up to 3 CDs can be treated at one time ‐ placed on the “”Thunderon Tape®
* Time to eliminate static may vary depending on season and environment.
* Treatment times for LPs or CDs that have been recently cleaned with a liquid should be longer.
* It is possible to also treat cables in the SK‐EX‐III with the lid open –treat both sides of the cable.
Model number: SK‐EX‐III
Size: W345 x D340 x H18mm
Weight: 850g (Net)
svartkeiko
9395 KALDFARNES
Furutech Static remover.
Denne ser svært interessant ut.Når man ikke var så smart å kjøpe ultralyd-vasker så er kanskje dette alternativet.Har du prøvd Static remover Paul?
Den ser jo ut til å være svært enkel å bruke.
Mvh Kenneth
pmaudio
Mvh Kenneth
Hei Kenneth,
Jeg har ikke hatt mulighet til å prøve den enda - da de første kommer til lager om ca 2 uker
Men produktet fasinerer meg og jeg tror på hva de markedsfører her.
Nå er det jo ingen produkter på markedet av denne typen som kan lure meg ( oss ) da vi har måleinstrument for å måle resultatet - og det feiler aldri - vi får alltid et konkret svar på måleinstrumentet om det virker eller ikke.
Så bare følg med - jeg skal legge ut resultatet når vi har gjort de første testene
Paul
McLaren
Hva er det dere måler og hvaslags måleinstrument bruker dere?
Hva vil pleier normanverdien å ligge før behandling av tilsvarende sort og hva måler dere etterpå omtrent?
McLaren
svartkeiko
9395 KALDFARNES
Mvh Kenneth
Hei Kenneth,
Paul
Takk Paul. Det er alltid noen "problem LP" i en platesamling og jeg har noen som jeg ikke blir riktig fornøyd med.Selv om jeg vasker de i min Smart vasker og etterpå bruker antistat-pistol blir jeg ikke helt fornøyd med resultatet.Jeg tenker at Static remover kan være et supplement til min platevasker.Skal følge tester som dere skal gjøre med stor interesse.
Mvh Kenneth
svartkeiko
9395 KALDFARNES
McLaren
Her er det nok ørene som blir det beste måleinstrumentet tenker jeg.De feiler sjelden.
Mvh Kenneth
Audiomix
pmaudio
McLaren
Det er et måleinstrument designet for å måle statisk elektrisitet - her under navnet EG Locator.
Måles i kV
Verdiene vi normalt får på LP plater kan være mellom -5 til -15 - avhengig av bl.a. årstid og luftfuktighet
Etter behandlingen skal vi helst komme ned til 0,00
Hvor lett og raskt det er å komme ned til ca 0,00 avhenger av de samme fakta - bl. a. årstid/luftfuktighet
Paul
pmaudio
Kjenner ikke instrumentet til Paul, men sikkert noe som dette:
Static meters measure static electricity. Electrostatic voltmeter static electricity static control or anti static products Electrostatics help you to identify problems related to static electricity static Control Static Charge Static Electricity Sta
Godt kjent fra elektronikk industrien.
Litt mindre aktuelt nå som (nesten) alle arbeidsplasser der det håndteres elektronikk er ESD sikret.
Hei Mixer`n!
Dette er nok èn av de som kan brukes ja
Dessverre er ikke lytterommene og platene våre ESD sikret!!
pmaudio
Er det et produkt som om 5 år, bliver kaldt "Snakeoil"...altså, min første tanke, men håber da, at jeg tager fejl :confused:
Dette er nok ikke et produkt i "snake oil klassen"
Alle som har holdt på med platespillere og vinyl bør kjenne godt til problemet med statisk elektrisitet - så dette er ganske reelt.
Spørsmålet er om dette produktet fjerner statisk elektrisitet eller ikke
Det får vi snart svar på - etter de første testene og målingene
Men Furutech pleier ikke å feile på disse tingene
Nå har vi jobbet med tilsvarende produkter fra Furutech i mange år - sikkert 10 år - og de er fremdeles relevante og ikke lagt over i den velkjente snake oil skuffen.
Et alternativt produkt som vi bruker hver eneste dag er DESTAT III
PM Audio
Paul
DagT
Det som måtte være snake oil er vel om det har noen betydning på CD-plater :)
Audiomix
Alle ikke ledende materialer kan bli statisk ladet.
Jo bedre isolator, jo mer statisk.
Google finner lesestoff for alle som er interessert.
Problemet har vært kjent siden grekernes storhetstid.
Ikke noe nytt altså.
Aurora
Ytterst i havgapet...
Men prisen, da mann.... du får ei godkjent antistatmatte for en brøkdel av prisen - det er kun det dette er..... og med "utladning" gjennom kroppen...
og til slutt bidrar faktisk PUen gjennom friksjon mot plata til ny oppladning.....
danelectro
Statisk elektrisitet og lper er definitivt et problem, men kan denne noe som en Milty Zerostat ikke kan?
Witthoff
Fra der hvor spiritussen er billig, Denmark.
Men prisen, da man.... du får ei godkjent antistatmatte for en brøkdel av prisen - det er kun det dette er..... og med "utladning" gjennom kroppen...
Produktet bør kunne købes med fuld retur-ret (Produktet skal være tilgjengelig med full back-rett.).
En helt anden ting, er at det omtalte produkt, med især den pris det sælges, ligger op til kopi-vare.
motoren
Flekkefjord
Produktet bør kunne købes med fuld retur-ret.
Kopi vare til den vanvittige prisen?
pmaudio
pmaudio sine annonser
Nye sendinger fra Analogue Productions og Mobile Fidelity ankommet
  • 1
Siste sending fra Analogue Productions ankom i går, med bl.a. Steely Dan Aja UHQR og The White Stripes - Elephant UHQR, Genesis, Phil Collins mm... Se her...
Ny sending fra Analogue Productions og Mofi har landet
Vi kjører på og bygger lager på Analogue Productions og Mobile Fidelity - og andre Undertittelen på PM Audio logoen i dag er: HIFI OG MUSIKK, som refererer til både hifi-utstyr pluss LP plater...
Enda en nyhet fra Frankrikes referansemerke - Metronome: AQWO 2
AQWO 2 etterfølger den første integrerte SACD/CD/DAC spilleren ( AQWO 1 ) hos Metronome AQWO 2 er en fullverdig DAC / CD / SACD spiller pluss Streamer Til mer info på nettbutikken...
Metronome NYHET igjen:: Le Streamer
Siste skudd på Metronome Classica serien - Le Streamer I motsetning til DSS 2 så har Le Streamer et tradisjonelt dimensjonert Metronome kabinett Le Streamer is the latest network player from...
NYHET igjen fra Metronome:: DSS 2 Streamer / nettverkspiller
Så er tiden inne for neste generasjon Metronome DSS streamer - DSS 2 Akkurat kommet i hus og vi er spent på resultatet Kontaktinfo: e-mail: kontakt@pmaudio.no Tlf.: +47 917 13 655 Til...
DEMOSALG av Gold Note XT-7 Gulvstående høyttalere
  • 3
Fantastisk italiensk finish Fremstår som nye Lydsignatur: Heller mot det varme En bånddiskant som for en gangs skyld ikke er skarp/spiss og ubehagelig for følsomme ører Meget lite brukt og har...
