Endpoint Audio importerer Bricasti Design M1 DAC til Norge.
Jeg har fulgt med denne dac'en siden den fikk sine første tester i 2011. Oppgraderingene har stadig kommet, og de har fintunet denne over de siste årene.
Den har fått noen knalltester, og nå er siste utgave på vei til Norge.
Ranket som klasse A+ i Stereophile!
Her kan man lese testene som er gjort: Bricasti Design
The Bricasti Design
New Model 1 USB Digital to Analog Converter
The M1 digital to analog converter is a dual mono design; there are two completely isolated channels, each with its own dedicated linear power supply, D/A converter, DDS clocking, and analog circuitry. This design insures that analog cross talk is virtually non existent, that the necessary power requirements for each channel are well met and isolated from each other and the digital processing is isolated, having its own power supply. With our twin DAC design, the dynamic range for each channel is optimized by using the stereo ADI 1955 D/A converter in a mono configuration. The M1 also includes Bricasti's own proprietary filter technology, further opening new territory with what is achievable in a modern D/A reference.
Product Highlights
  • DSD playback.
  • Features the latest generation asynchronous USB interface.
  • Dedicated dual mono design.
  • Highly acclaimed, proprietary filter technology.
  • Extremely low jitter @ 6 picoseconds.
  • Supports sample rates of up to 192khz and 24 bits.
  • Minimum and linear phase filters.
Pris: 79.900,-
Tom Egil
tom@endpointaudio.no
+47 47832922
Endpoint Audio
Endpoint Audio sine annonser
Acoustical Systems - Endpoint Audio
  • 3
Endpoint Audio gjenopptar agenturet for Acoustical Systems i Norge Jeg er stolt over å kunngjøre at Endpoint igjen er den offisielle distributøren av Acoustical Systems’ høykvalitetsprodukter i...
Nyhet fra Canor - Canor Virtus A3, alt i ett forsterker.
  • 2
Canor har endelig lansert sin nye alt i ett enhet. Klasse A/AB, 6 digitale innganger, 4 analoge innganger, 1 phono MM/MC inngang. I tillegg har den hodetelefonutganger i fronten - balansert og...
Black weeks hos Endpoint Audio - 15-20%
Jeg kjører tilbud på en rekke merker ut november. Horns - 20%. EMT og Thales - 15%. Canor 15%. Norma - 20%. Ring eller send mail for tilbud om det er noe du ønsker...
Lagertømming av Lumin. - 40%
Jeg har noen få Lumin U2 mini igjen på lager, og selger ut disse med ca. 40% avslag. Nå 18000,- https://perfect-sense.se/varumarken/lumin
Høstkampanje på Canor Produkter hos Endpoint
  • 2
Jeg kjører igang en høstkampanje på alle Canorprodukter. -20% på alle enhetene. Canor Audio har utviklet og produsert Hi-Fi-elektronikk i over 25 år med spesielt fokus på rørbaserte løsninger. I...
J. Sikora Reference - 1 av 4 A+ rankede i Stereophile
J. Sikoras toppspiller er også den "billigste" A+ spilleren Stereophile har ranket - Prisen er 48.000 USD (389.000,- i norge) + arm. Michael Fremer hos Stereophile har testet J.Sikora Reference...
