1974/67 X- / FI System (nesten) Resurrected
  • WayAhead
    Sky No Limit....
    Har startet "rekonstruksjonen" av det gamle x/FI anlegget fra 1974. Det gjenstår noe arbeid på ES200 høyttalerene så på opptaket under er disse erstattet med lilleputtene JBL Control 1Xtreme. Lydopptaket (se bort fra bakrunnstøy osv gad ikke gjøre det om igjen) er utført med ZOOM*H5 i 44/16 og er ikke "redigert" eller tuklet med på annen måte. Lyden som her gjengis rettferdiggjør naturligvis ikke det man hører - tross alt...
    Det blir garantert et "løft" i lyden når ES200ene er oppe & spiller. Regner med å poste ny video da. Well, ....
    http://vimeo.com/307357930
    "Materialliste:"
    SR-212
    ADC ZLM
    AMP
    LI
    FIED
    AU-9500
    Bildet viser en annen modell men de er like å se på.
    ES100
    ES200
    Om lillebroren ES100:
    https://vinylborsen.com/hogtalare/21414-sansui-es-100.html
    SANSUI AND EVERYTHING CLEAR ...
    Sansui ES-100
    The set presented is a modest-looking loudspeaker design with great sound. This is an outstanding example of the fact that a wisely planned housing is half the battle. These two-way compact monitors provide unique musical information. The music that flows from them sounds extremely emotional. The sound is incredibly spacious, detached from the housing. Microdynamics at a very high level. The construction from the 70th year could be a model for modern monitors. Beautiful masks in the style of Kabuki, monitors extremely universal in sound. Lars Danielsson and his album "Mélange Bleu" from 2006 served us to listen to this remarkable construction. The music composed by the same tales, including Bugge Wesseltoft and Nils Petter Molvaer. Norwegian musicians, who largely dominated the scene of new jazz in Europe. The record was released in the famous Munich outbuilding of ACT music. This label has been known for many years from a high artistic level and above all from great realizations. Sound sophisticated, for a listened audiophile, on which the "flexing muscles" and the huge dynamics are no longer impressive. Here we have a great culture. Very natural and not over-drawn high tones. Subtlety and delicacy, which is so rare in contemporary loudspeaker constructions. High efficiency, makes the Sansui ES-100 are also ideal for low power amplifiers, as well as tube designs, I heartily recommend.
    WayAhead
    Sky No Limit....
    Giotcha.....
    Fikk tak i et par komplette ES200 i nær mint stand men skal også restaurere det andre paret jeg har og... så nå er hele riggen oppe Å lØper ila noen dager...
    Illustrasjonsbilde...
    WayAhead
    Sky No Limit....
    Today's The Day. Mottok ES200ene i går kveld. De var i helt original og feilfri teknisk stand og spiller akkurat som jeg husket og forventet. Får klippe litt fra omtalen av lillebroren for å recapturate. Selvsagt helt umulig å formidle hva dette faktisk er i praksis.
    Sansui ES-100
    Treveis trykkammerhøyttalere med bass gom går fra 30 til 1500 gir en helt utrolig lekenhet, dynamikk og artikulasjon i hele dette området og dome mellomtone og diskant kompletterer perfekt..
    Har laget to klipp med opptak som naturligvis ikke kan rettferdiggjøre hvordan det høres ut i virkeligheten men legger de ut likevel. Begge opptakene er fra Sgt Pepper, Within You, Without You vinyl versjonen. Det første er fra en 1967 stereo original, det andre er samme sang men US mono versjon (vinyl). Den siste er i forferdelig stand foreløpig men en burde kunne høre forskjelll på de to versjonene.
    Stereo: (blir lagt ut på nytt på Vimeo senere)
    BLOKKERT AV YT GÅ NEDOVER
    Mono: (blir lagt ut på nytt Vimeo senere)
    geirendre
    Bodø
    Å legge originale Beatles spor ut på YouTube er nok å be om trøbbel.
    Er vel knapt noe annet som trigger Copyright trollene hos Google mer enn nettopp det.
    Og så på 50-års dagen for Tak konserten deres da, hehe.
    Hvor mange (eller få) sekunder gikk det før de ble fjernet? :p
    WayAhead
    Sky No Limit....
    Når det gjelder de to siste er jeg usikker men nokså raskt. Let It Be filmene klarer seg greit på Vimeo enn så lenge. Skal legge ut disse to siste på Vimeo men må rydde litt først har brukt om kvoten men skal få ordnet dette. :)
    Lurer forøvrig på om Google er i ferd med å sluke Vimeo og Twitter og... synes jeg så noen stygge indikasjoner på Vimeo.
    WayAhead
    Sky No Limit....
    Ikke spesielt inngående "test" av ES 200 høyttalerene men en kan få et inntrykk av hvordan forskjellen mellom 1967 mono vs stereo fungerer. Monoutgaven har veldig lavt lydnivå så den er boosted for å matche stereoutgaven. Begge er slitte spes monoutgaven. Mer infor følger senere.
    WayAhead
    Sky No Limit....
    Noen detaljer fra 1974 platespilleren Sansui SR-212:
    Internkoblingen - ledninger fra pickup til mellomkoblinger til RCA kontakter bak på platespiller. De tynne ledningene kommer fra Pickup/arm.
    Samme
    Utrolig tynne saker ledningen fra PU/arm. Vrient å jobbe med. Måtte ta jobben da pickuparm måtte/burde ifm at den fikk 23kg forsterker over seg.
    Originalkabel (phono/RCA) som fulgte med platespilleren. Legg merke til den ufattelig tynne dimensjonen på selve lederen. Av denne grunn takket den dessverre for seg etter rundt 40år. Brudd i lederen på flere steder. Super kabel/lyd, vanskelig å finne erstatning men jobber med saken.
    Samme
    WayAhead
    Sky No Limit....
    Today's the day... (nesten)
    Fikk tak i en hel og fin Sansui SR-212 til erstatning for den som fikk forsterkeren over seg og ikke nok med det, original-phonokabelen som jeg har slitt veldig med å finne en fullgod erstatter til på den gamle spilleren følger med denne og i tillegg til en nymotens greie av foreløpig ukjent opprinnelse (oelbach av en eller annen type viser det seg. En av fordelene med denne er at den er bygget som en tanks og vil vare forever med unntak av drivreimen men det er lett å finne erstatninger. Motormekanikken har oljesmøring via små plastrør under platetallerken. Armoppheng, lagring osv er tilnærmet nullfriksjonsløsninger. Enkel, robust og evigvarende samt stor fleksibilitet mht pickuper osv.
    Det følger og med en MC pickup av typen High Output Satin 117Z produsert i Japan, en får se hva den er god for men beskrives som meget bra mht lydgjenivelse,
    Here’s a beautiful candy apple red Satin M-117Z moving-coil cartridge. This is a very rare HO moving coil. The cartridge is very clean and it sounds superb, with excellent imaging, separation, and dynamics. The soundstage is to die for with a prolific 3-D sound that is very holographic in nature. The stylus is sharp and clean, showing very little wear. This baby looks like new! Specifications: Type: Hi-Output moving coil Cantilever: aluminum alloy Tracking: 1.0-2.2g Output Level: 2.5mv Frequency Range: 20Hz-20,000Hz Cross Talk: 20 dB Impedance: 40 ohms Weight: 9.2g
    Ich verkaufe meinen wunderschönen Sansui SR-212 Plattenspieler inkl Oelbachkabel.
    Er hat dem alter entsprechend einige Gebrauchsspuren auf dem Deckel.
    Klingt und spielt noch wunderbar :D
    Originalkabelen
    Oelbachkabel står det visst i beskrivelsen, vi får nå se kvisles han let.....
    WayAhead
    Sky No Limit....
    Og ikke nok med det, fikk spilleren P-M90 for et par dager siden, den som spiller begge sider av en vinylplate uten å snu platen. Dette er et komplekst monster men ikke uoverkommelig. Den mangler kun en drivrem for å spille ser det ut til. Nokså omfattende å demontere denne. spilleren har to tangentialarmer, en over og en under, begge sitter på samme sleiden og beveger seg sammen, sammen. Største problemet med denne er at jeg tror noen har sprayet den med noe som har gjort at reima har gått i oppløsning og det finnes rester av den på flere steder som må renses, enten med Aceton eller Lighterbensin. Konsistens som lakrispastiller som har smeltet i solen opphøyd i 10. :)
    Spilleren er utstyrt med børster som renser stiftene når de parkeres i posisjon.
    Well...
    ATTACH=CONFIG]537166[/ATTACH]
    WayAhead
    Sky No Limit....
    Hmmmmmmm.... Mission Completed....
    Det er nå full ren original Sansui linje fra stift til høyttalere, designet og produsert av Sansui - og det høres - beyond mulig å beskrive for å si det sånn.
    Oppsett:
    Sansui Pickup SC-28/37 1974
    Sansui platespiller SR-212 1974
    Sansui phonokabel designet - også - for Quadrofoni.
    Sansui Forsterker AU-9500 1974 (1969)
    Sansui høyttalerkabler PS-112C mid 70ish
    Sansui Høyttalere ES-200 1974.
    Det er flere generasjoner siden jeg ville vært mer enn fornøyd med lyden i dette anlegget men nå har det nådd noe som er umulig å beskrive men noen eksempler:
    Systemet er voldsomt lineært og punchy men veldig detaljert og nyansert og henter ut detaljer fra noen av objektene (platene) som ikke er mulig å høre uten videre på 96/24 digitalfiler rett i digitalsystemet eksempelvis. Har sikkert litt med mix-masteringen å gjøre også.
    Den enkle versjonen:
    Cat Stevens - best of.. har aldri fått med meg at gitaren hans er stemt falsk, kanskje falsk men dette er på grensen av grotesk. Rytmesekjonen grenser til "invers" og oppleves i helt annen balansering.
    Abbey Road original 1969. "Du" har aldri hørt den så punchy og fet - garantert, digital - as of yet - er ikke i nærheten uansett standard, 1974 anlegget har alltid levert überfenomenalt her men dette...
    Zappa, husker ikke LP, men Joe eller U R ... foruten å være nesten "too much" jevnt over, men på en av låtene - på utfadingen hører men 2 personer snakke sammen i mot høyre, de har ikke fått med seg at opptaket fortsatt er på. Dette er nok hørbart vanligvis men her er det såpass tydelig at en fornemmer at en ny sang begynner.....
    Well, kanskje blir det en uavhengig betraktning på dette ved anledning.... until then.... Gudd 17. Mai og alt D dÆærre dÆr....
