Resultater 1 til 2 av 2
Abonnér på denne tråden
  1. #1
    Hifi-entusiast rveum's Avatar
    Jun 2005
    Tagget i
    0 Innlegg
    Harman Kardon AVI 150
    Ikke akkurat Vintage, men jeg prøver alikevel.
    Fikk denne i dag er en gammel suround forsterker, den virker men jeg har ikke noe info på den.
    Er det noen der ute som har info på denne.
    Årstall ?
    Watt ?
    Mangeler fjernkontroll så hvis det er noen som vet hvilken kodesystem H K bruker så hadde jeg blitt glad for info.
    Stue anlegg Tandberg 4038 pre&nbsp; Doxa 140 Singnature<br />Vintage anlegg Rotel RX 1603 Sony X339ES<br /><br />Har også Tandberg Huldra 2,4,6,8,9,10,11&nbsp; TR200 TR1000, TR 1010, TR 1040, Sølvsuper 2,5,10,11,12C og en del annet morro.
  2. #2
    May 2005
    Tagget i
    0 Innlegg
    Re: Harman Kardon AVI 150
    A review by Timbronze on Harmon Kardon AVI 150
    September 2nd, 2005 www.ciao.co.uk
    Product details about Harmon Kardon AVI 150
    Main Specs
    Manufacturer Harmon Kardon
    Dolby / DTS Dolby Digital
    RMS Wattage 65
    Width in mm 443 mm
    Sound Quality Excellent
    Ease of Use Simple
    Look & Design Excellent
    Range of Features Diverse
    Value for Money Good
    Advantages: High Quality Output, Clean Stylish Look, Mulitple Format Connection
    Disadvantages: A little Bulky . Dont place DVD above Amp may over heat
    Recommend to potential buyers: yes
    Full review
    What an excellent DVD Amplifier.
    The amp once connected provides great sound quality. The amp supports a variety of external products, including DVD, HI-Fi's. TV, Game stations etc..
    It is so diverse and I would recommend to any one.
    The sound when in surrond mode is phenominal, you can here everything in super high quality.. It often really makes you feel like your there.
    The Amplifier comes with a Easy to use remote that allows you to control every feature of both the amplifiers itself and also the recommended DVD from Harmon Kardon.
    The product is well worth every penny you pay for it.
    The style is very cool and would fit in well in any household. The DVD player is also of a similar look and would make for a great system.
    Til bruk er det laget, brukt skal det bli!
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
