Harman Kardon AVI 150
rveum
Ikke akkurat Vintage, men jeg prøver alikevel.
Fikk denne i dag er en gammel suround forsterker, den virker men jeg har ikke noe info på den.
Er det noen der ute som har info på denne.
Årstall ?
Watt ?
Mangeler fjernkontroll så hvis det er noen som vet hvilken kodesystem H K bruker så hadde jeg blitt glad for info.
Masterdude
A review by Timbronze on Harmon Kardon AVI 150
September 2nd, 2005 www.ciao.co.uk
Product details about Harmon Kardon AVI 150
Main Specs
Manufacturer Harmon Kardon
Dolby / DTS Dolby Digital
RMS Wattage 65
Width in mm 443 mm
Sound Quality Excellent
Ease of Use Simple
Look & Design Excellent
Range of Features Diverse
Value for Money Good
Advantages: High Quality Output, Clean Stylish Look, Mulitple Format Connection
Disadvantages: A little Bulky . Dont place DVD above Amp may over heat
Recommend to potential buyers: yes
Full review
What an excellent DVD Amplifier.
The amp once connected provides great sound quality. The amp supports a variety of external products, including DVD, HI-Fi's. TV, Game stations etc..
It is so diverse and I would recommend to any one.
The sound when in surrond mode is phenominal, you can here everything in super high quality.. It often really makes you feel like your there.
The Amplifier comes with a Easy to use remote that allows you to control every feature of both the amplifiers itself and also the recommended DVD from Harmon Kardon.
The product is well worth every penny you pay for it.
The style is very cool and would fit in well in any household. The DVD player is also of a similar look and would make for a great system.
