Side 44 av 44 FørsteFørste ... 34424344
Resultater 861 til 868 av 868
Abonnér på denne tråden
  1. #861
    Hifi Freak
    Nov 2007
    Siggerud
    Tagget i
    1 Innlegg
    Hei. Jeg har riktignok ikke IMF, men mine gamle Atkinson TL er såpass like TLS80 at det samme burde gjelde dem også.
    Jeg synes B110’ene låter litt sløvt, de spiller ikke helt så bra som jeg vet de kan, eller burde kunne.
    Har noen av dere erfaring med det som beskrives i innlegget jeg kopierte fra et amerikansk IMF-forum?
    Edit: Det er mulig dette har vært tatt opp før, men jeg har ikke lest hele tråden. Har ikke prøvd å oppgradere filtrene ennå.
    My new Falcon B110 arrived yesterday. I wasted no time and installed them immediately. First of all, the originals are from 1972. That puts them at 47 years of age, quite old. I bought the new B110s for this reason. Though they still work, it's doubtful they are still operating as they did when new.
    I did what I usually did, which is install one and compare it to the original. Using a mono signal and swapping between the two speakers was interesting to say the least. The new driver sounded lighter, clearer and more natural. And, not a small amount either. It was a significant difference. Enough of a difference that I had to recheck my wiring to make sure I had the new one hooked up the same. But, after confirming that, it was obvious the new B110 sounded much better.
    Once I was happy with the new B110, I installed the other one and spent some time listening. Wow, I cannot believe the difference! Is this what a B110 is supposed to sound like? Unbelievable. No wonder it has such a cult following. Vocals sound so great now, the murkiness that resided here is gone. The sound field has so much more depth, guitars sound incredible.. the list goes on. I was expecting a difference but not this much. It's like the speaker was recapped (which it already is).
    I do think that this difference largely accounts for the age of the driver and it's production run. These are old B110s with silver frames so perhaps the construction materials don't age as well. But either way, I can confirm that this is a very worthwhile upgrade. Should you do it? If you have IMFs from the late 70s, probably. But I can't guarantee the same results since it's impossible to say what working condition yours will be in. However worst case scenario, you end up with a brand new set of B110s and have backups for years to come.
    In short, bravo Falcon. I'm so glad I bought these. Now to figure out how to fit the new B139..
    Siste redigert av Petre; 02.06.2019 kl. 15:13.
  2. #862
    Hifi-entusiast
    Nov 2007
    Tagget i
    1 Innlegg
    Jeg ville i allefall ha gjort det, de koster tross alt ikke mye. Ville samtidig ha skiftet kondisene i filteret til Mundorf Alu in oil. Da skjer det mye positivt
    Kuzma Stabi, Wheaton Triplanar MkIII, Benz Ebony LP, Linn Linto, Copland CD288 XO-clock, CarySLP308, Mcintosh MC2102, AKG701Ref, IMF RSPM MKVII,Infinite Resolution, Isotech minisub
  3. #863
    Hifi-entusiast Tor-S's Avatar
    Jan 2013
    Bjerkvik
    Tagget i
    0 Innlegg
    Har ikke lest en vondt ord om falcon sin nye B110
    - Sansui AU-999
    - Audio-GD Master 7
    - Yamaha CDX-1060, Yamaha S2700, PS1 scph-1001, PC SoTM exp, Lenco L75
    - IMF RSPM mkVII, IMF RSPM mkIV, IMF TLS 80-2
    - Div diy sølv kabler
  4. #864
    Jun 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra Tor-S Se Innlegg
    Har kjøpt et par til
    Vedlegg 542586
    Du som kjøpte de CM2'ene fra han i Sandnes (eller var det Stavanger)? Jeg også vurderte dem, angrer på at jeg gav mine gamle til min bror da de hadde vært fin å ha i et oppsett nr 2... Selv de små IMF'ene spiller veldig bra synes jeg, du burde få deg en Audio Innovations S500 forsterker til dem, det er i alle fall min plan når jeg får kjøpt et par CM2 igjen, og så skal de få platespilleren jeg spiller på nå når den skal oppgraderes. Gratulerer med enda ett par IMF forresten, tre par du har nå?
    Høyttalere: IMF Electronics Reference Standard Professional Monitor Mk.IV (Improved)
    Forsterker: Rotel RC-1572 / Rotel RB-1090
    Platespiller: Sony PS-11
    Digital Kilde: Marantz UD-7007 & Marantz NA-6005 & Squeezebox Touch
  5. #865
    Jan 2013
    Bjerkvik
    Tagget i
    0 Innlegg
    Sitat Sitat fra Jan-Helge Se Innlegg
    Vedlegg 542586
    Hei. Ja det var meg. Ikke at jeg trengte dem. Syns de e steike lys i målet, det er byttet til ALCAP i dem, ser skikkelig ut, men så bortinatta tynn i målet. Slik skal de vel ikke være?
    Har 4 par faktisk om jeg telle med det paret med TLS80-2 som jeg låner ut til brodern for tiden.
    - Sansui AU-999
    - Audio-GD Master 7
  6. #866
    Jun 2007
    Tagget i
    0 Innlegg
    Vedlegg 542586
    De jeg hadde var ikke lyst-klangende, syntes de hadde en klang som var oppsiktsvekkende lik de store transmissionlinerne til IMF, den klareste forskjellen var i grunn at de ikke strakk seg like dypt ned i bassen... Men altså, selv om man er vant med store IMF'er så ble i alle fall jeg voldsomt overrasket av CM2'ene og bassgjenngivelse ble ikke noe savn... Snarere tvert imot så imponerer de nedover i frekvens sammenlignet med andre stativhøyttalere.
    At de låter lyst kjenner ikke jeg igjen, så mulig det ikke er ideelt med delefilteret slik det står nå... Jeg likte mine så godt at jeg sterkt vurderer å kjøpe et par igjen og bygge opp et andre oppsett for dem, og det oppsettet kan jeg leve godt med og være fornøyd med da det ikke vil stå mye tilbake for RSPM'ene (Så gode synes jeg CM2'ene var)...
    Hvorfor dine låter lyst aner jeg ikke, jeg er ikke den mest tekniske i så måte, men skjønner at noe må være feil i og med at de jeg hadde spilte med en klang som var veldig familært med alle øvrige IMF-modeller jeg har hørt. Prisen tatt i betraktning og størrelsen også, de er utmerkede musikkformidlere rett og slett og jeg kan ikke få rost dem høyt nok.
    Leste ett sted at noen som har skiftet delefilter på sine IMF'er (Falcon sine) opplevde at disse ble mer lyst-klingende, men der jeg leste det var det i positiv forstand. Selv har jeg ikke skiftet på mine modeller, av flere grunner bl.a. fordi jeg hverken har loddebolt eller teknisk kunnskap om det, men var for mange år siden i kontakt med Eltek (nå dynabel) med en forespørsel om hva det ville koste om dem gjorde jobben for meg. Så selv har jeg ingen erfaring på før kontra etter med slik, men det har jo du som har eksprimentert med dette på dine RSPM... Var derimot en annen modell jeg leste at høyttalerne ble mer lystklingende i ettertid, hvilken modell det var husker jeg ikke i farten da det er en stund siden jeg leste det.
    Også lest et sted at Falcon sine erstatnings-elementer er mer lystklingende enn orginal-elementene, men heller ikke det har jeg erfaring med selv. Men tenkte at dersom jeg en gang skulle kjøpe et par med flate Kef elementer igjen, så skulle jeg handle de nye elementene og prøve meg frem, også mellomtonen... Men vet ikke om fremtiden bringer meg dit?
  7. #867
    Jan 2013
    Bjerkvik
    Tagget i
    0 Innlegg
    Se hva som dukket opp i dag
    IMF MCR2A
    Navn:      IMG_20191029_172448.jpg
Visninger: 110
Størrelse: 98.0 Kb
    Navn:      IMG_20191029_172424.jpg
Visninger: 109
Størrelse: 157.1 Kb
    - Sansui AU-999
    - Audio-GD Master 7
  8. #868
    Jan 2013
    Bjerkvik
    Tagget i
    0 Innlegg
    Vedlegg 542586
    Takk for svar.
    Jeg skal ta de opp en dag å sjekke verdiene på delefilteret. Alt jeg vet er at det står ALCAP på filteret på CM2ene, men ikke sikkert verdiene er rett.
    - Sansui AU-999
    - Audio-GD Master 7
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
