Side 51 av 173 FørsteFørste ... 41495051525361101151 ... SisteSiste
Resultater 1,001 til 1,020 av 3460
Abonnér på denne tråden
  1. #1001
    Jan 2016
    Tagget i
    0 Innlegg
    Yes, just get an adaptor for speaker male -> XLR female. This is also safer because when you insert your XLR male into this adapter, the ground goes in first. Mine even has a jumper at the end, because the H20 has bi-wiring capabilities
    Just be careful with the volume, of course- in between your DAC and your Power Amp you'll need a preamp for volume control, but then you're all set.
    On the other hand if you're using the H160 integrated, then just get the adaptor, you don't even need to worry about the pre!
    PS, I also have the Taurus MKII. It's a nice headphone amp- clear, revealing, just a bit bright, but treble is not piercing so that's nice. The Hegel (driven from the Taurus' preout, no less) sounds expansive, stronger, smoother, and has deeper, more textured bass. I definitely prefer the latter.
    Example of the adaptor (not mine):
    Navn:      2d17848e_HE6XLRcable.jpg
Visninger: 1060
Størrelse: 125.7 Kb
  2. #1002
    Jan 2016
    Tagget i
    0 Innlegg
    If you are willing to go HE-6 direct to speaker taps (I was doing this for a long time too, actually), there's one for sale right now in the Torget:
    BTG 8 Strand SPC til Hifiman HE-6 - Torget
  3. #1003
    Hifi-entusiast Kirenoj's Avatar
    Mar 2012
    Porsgrunn
    Tagget i
    0 Innlegg
    Was this for me? Anyways.. I have just bought the HD800 so there`s a no go for the HE 6. But its on my list for "want to try headphone". Beacause i have read several places that its very good with the Taurus.
  4. #1004
    Jan 2016
    Tagget i
    0 Innlegg
    Sitat Sitat fra Kirenoj Se Innlegg
    I have the Taurus. Works quite well with the HE6. My H30 is better, especially in the bass, and sense of space. But the Taurus gets you 90% there.
  5. #1005
    Dec 2014
    Tagget i
    0 Innlegg
    Spennende ting på horisonten - har booket en H160 for hjemlån i morgen! Har per i dag en HD11 koblet balansert til en H70, så det bør være hørbare forskjeller
    Blir mest interressant å høre hvor mye høyttalerene har å by på, om de vokser med oppgraderingen. Har Dynaudio Excite X16, noen som har erfaringer med disse?
  6. #1006
    Hifi-entusiast
    Jan 2015
    Tagget i
    0 Innlegg
    Sitat Sitat fra bardust Se Innlegg
    Du vil få et kæmpe løft i lyden med en H160 til dine Dynaudio'er
  7. #1007
    Dec 2014
    Tagget i
    0 Innlegg
    Sitat Sitat fra Rene.J Se Innlegg
    Det som er med X16 er at de har jo et ganske stort basselement (18cm) som skal ta seg av både bass og mellomtone. Jeg har ikke prøvd andre forsterkere på de men det virker som H70'en hadde nokså god kontroll og balanse, og med HD11 så ble alt hakket strammere. H160 har jo dobbelt så mye krefter å by på så jeg forventer vel at det skal bli enda bedre balanse mellom bass/mellomtone og diskant.
  8. #1008
    Hifi Freak ChrisAndre's Avatar
    Sep 2013
    Fredrikstad
    Tagget i
    2 Innlegg
    Bare å glede seg
    Hifi rommet: Technics SL-1210M5G KAB PS1200GX - KAB Fluid damper - Nagaoka MP-110 - Schiit Mani - Klipsch RP260 Limited Ed. - Kimber 4TC/ Nordost
    Rega Elex-R - Rega RP3 SE m/ Tangospinner dual belt - Rega Neo PSU - Rega Exact MM - Rega Fono MM mk3
    I stua: Klipsch RP280F Dolby Atmos -Marantz SR7011 - Philips 873 OLED - Sony UBP-X800 4K SACD
  9. #1009
    Moderator Bjørn.H's Avatar
    Jul 2004
    Tagget i
    8 Innlegg
    Navn:      IMG_20150211_095224_edited.jpg
Visninger: 868
Størrelse: 38.0 Kb
    HD11 er fortsatt en meget god DAC.
    Hegel H90, PrimaLuna ProLogue Classic, Monitor Audio GS20, Gold C150, Reloop Turn5 m/Clearaudio Virtuoso, Rega Fono MM, Bluesound Vault2, Chromecast, BJC, Yamaha RX-V3800, Sony BDP-S5500. Focal: Chorus 736S, Chorus CC700S, Chorus SW700S, Chorus 706S m/org. stat.
  10. #1010
    Overivrig entusiast TrondW's Avatar
    Nov 2012
    Bergenser i Ålesund
    Tagget i
    0 Innlegg
    Sitat Sitat fra bjornh Se Innlegg
    Har du sammenlignet den med HD20? Ser prisen på dem er blitt ganske lik etter hvert. Legges ut for rundt 3000 for hd11 og 4000 for hd20.
    1. PMC Twenty5.22 - Devialet Expert 120
    2. Dynaudio Xeo 3
    3. JBL LSR 305 - Audiolab M-Dac
  11. #1011
    Jan 2016
    Tagget i
    0 Innlegg
    Really curious on the HD30, in case anyone has had a chance to try it. I have a Schiit Yggdrasil, wondering how it compares..
  12. #1012
    Hifi Freak oyvindl85's Avatar
    Aug 2013
    Tagget i
    0 Innlegg
    Sitat Sitat fra TrondW Se Innlegg
    Jeg har hatt begge disse og foretrakk klart HD20 da detteble testet. HD20 hadde mer balansert lyd.
    Følte HD11 be mer agressiv i toppen. Så jeg likte bedre HD20. Også bassen var bedre gjengitt.
    Så med ca 1000 kr som skiller dem vet jeg hva jeg selv ville valgt igjen
    System Audio — Primare
    Sennheiser Momentum — Denon AH-D5000 — Hegel Super
  13. #1013
    Jul 2004
    Tagget i
    8 Innlegg
    HD20 er nok hakket hvassere, noen synes HD11 virker strammere i lyden, noen at det er litt mer presens i toppen. En HD11 får du for ca. 3000,- brukt, en HD20 4500-5000,-. Det synes jeg det er verdt. Samtidig er HD11 ikke så voldsomt mye "dårligere" heller.
  14. #1014
    Hifi-interessert
    Sep 2015
    Ålesund.
    Tagget i
    0 Innlegg
    Sitat Sitat fra jelt2359 Se Innlegg
    HD 30 has been in my system ( together with H 360 in DAC-loop ) for about 2 months now.
    I have never heard Schist Yggdrasil, so I am not able to do any comparison between these two.
    But what I can say about HD30, is that it is a fantastic DAC in several ways, it is able to open up the sound and present a crystal clean sound,
    with an enormous wide soundstage, and also a very good depth in the stage. HD 30 presents the sound with a great deegre of separation between
    each instrument in the soundstage. In my opinion HD 30 is only limited by the quality of the signal it is beeing fed by.
    It does not add or subtract anything to H 360`s sound signature, it just opens up the sound to another level, presenting a truly enjoying sound.
    Test can be read on SoundStageNetwork.com | SoundStage.com
  15. #1015
    Jul 2004
    Tagget i
    8 Innlegg
    Navn:      DSC_7857_edited_edited.jpg
Visninger: 810
Størrelse: 70.2 Kb
  16. #1016
    Jan 2016
    Tagget i
    0 Innlegg
    Sitat Sitat fra Innvandreren Se Innlegg
    Thank you. Seems like a very good delta sigma dac, especially with the soundstage. Would you say it retains the Hegel house sound? I like that sound a lot in my H20.
  17. #1017
    hifierik
    Guest
    I agree on that one!
  18. #1018
    Hifi-interessert
    Sep 2015
    Ålesund.
    Tagget i
    0 Innlegg
    Yes, I would say it retains the sound from other Hegel components. But what is the exact Hegel house sound?
    My experience with H 360 is that it produces, in addition to a cleaner sound, also a slightly varmer sound, compared to H 300, witch I had before H 360.
    And in my opinion, this makes the 360 more enjoyable to listen to, even though I still consider H 300 to be a great amp.
    But HD 30 is strictly retaining the sound and sound signature from H 360, no dough about that.
  19. #1019
    Jan 2016
    Tagget i
    0 Innlegg
    That's great to hear! To me the Hegel house sound is clean and never harsh, with deep, impactful bass. It's not romantic, but doesn't lack smoothness.
  20. #1020
    hifierik
    Guest
    I agree on that one too!
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
