Side 161 av 161 FørsteFørste ... 61111151159160161
Resultater 3,201 til 3,213 av 3213
Abonnér på denne tråden
  1. #3201
    Hifi-entusiast Lassencad's Avatar
    Aug 2014
    Tagget i
    0 Innlegg
    Sitat Sitat fra Hornlyd Se Innlegg
    2450SL Truextent fra starten av
    Har testet 2450SL med standard aquaplas i M2 waveguide. Låt litt ullent i forhold. Da har jeg mer tro på Titan med tweeter.
    Okay
    Jeg har nu også forsøgt mig med et sæt 2405H . Men leder stadig efter et godt analog elektronisk delefilter .
    Ville så dele imellem 2432/2405 ved 9khz
    Må i gang igen snart
  2. #3202
    Overivrig entusiast oen's Avatar
    Mar 2010
    Tagget i
    0 Innlegg
    An Interview with Greg Timbers, Past Designer/Engineer for JBL
    An Interview with Greg Timbers, Past Designer/Engineer for JBL.
    By Dave Clark
    Greg Timbers
    My system consists of the following:
    2-channel:
    Everest DD67000, fully active 4-way
    DEQX HDP4
    DEQX Premate
    Pass Labs XVR1
    Parasound JC1, 4 amplifiers, 1 for each woofer.
    Quicksilver Mono 120, 1 for each large compression driver
    Pioneer Elite A-20, for UHF compression driver
    Pass Labs XP-15 Phono Stage
    Basis Audio Debut Turntable with SuperArm 9 and Dynavector DV-20x
    Tascam DA-3000, Digitizing LP's
    MacMini running JRiver Media Center 22
    PS Audio LanRover
    4 channel, All of the above plus:
    K2 S9900, fully active 2-way
    Pascal M-Pro amps within the speakers
    DEQX Premate for crossover and DSP
    Classe Audio CT-SSP
    Oppo BDP-103
    Oppo BDP-203
    JVC RS-600 Projector
    Stewart Film 110" Firehawk, 2.40:1
    LG 65" OLED
    All speaker cables and audio interconnects are StraightWire Virtuoso
    5 microphone array around listening position shows -3 dB @ 20 Hz and -6 dB @ 48 kHz. The 1/6 oct response of the 5 microphone average is less than +/- 1 dB from my target curve over that range. The system sensitivity (if passive) would be 96 dB for 2.83 v @ 1 m. Since the DEQX uses linear Phase (FIR) crossovers, I have the impulse of each individual transducer and its network aligned to less than 0.1 ms at the listening position. EQ and room correction is done in the DEQX, JRiver and the CT-SSP depending on input and overall system configuration. (Music, Phono, Movie}
    "Audio is filled with dangerous amateurs."
  3. #3203
    Aug 2014
    Tagget i
    0 Innlegg
    Hvis der er nogle i tråden der kunne have lyst til sådan en
    https://www.dba.dk/hoejttaler-jbl-pr...id-1059057439/
  4. #3204
    Overivrig entusiast Fluefiskeren's Avatar
    Nov 2004
    Kristiansand
    Tagget i
    0 Innlegg
    Er det nye gulvstående høyttalere på vei fra JBL? Mener å ha hørt at det er noe nytt på gang her?
    Stueanlegg: Kilder: Hegel CDP4AMKII, Clearaudio Concept m/Virtuoso Wood V2, Pioneer BDP-150, Pioneer CT-W505R Forsterkning: Hegel H590, Yamaha RX-A1050, Parasound NC275, Lehmann Audio Black Cube SE RIAA, Hodetlf.-oppsett: Rega Ear2/Sennheiser HD598, Høyttalerkabler: Nordost Red Dawn LS. Høyttalere:PMC DB1 Gold, Dynaudio Emit M10, Klipsch RC-64III, Arendal Sound Sub1 Bilde: LG Plasma, Optoma projektor/lerret
    Kjøkkenanlegg: Exposure 3010 S2/Denon DVD 3910/System Audio SA505
  5. #3205
    Aug 2014
    Tagget i
    0 Innlegg
    Sitat Sitat fra Fluefiskeren Se Innlegg
    Hvor har du hørt dette?
  6. #3206
    Hifi-entusiast Motorhome's Avatar
    Jun 2018
    Sunndalsøra
    Tagget i
    0 Innlegg
    Vil ikke akkurat si at det er det ''nye'' JBL som er det som er av interesse akkurat nå. Harman har satset mye på såkalt gadget og bluetooth produkter i det siste. Jeg liker bedre å holde på med vintage, eller rettere sagt ''old school''. Vil begynne å rekone et par D130 bass elementer som egentlig er et extended range element som også ble brukt i 2-veis system. Men også brukt til gitar og orgel (16 ohm). Ellers så må jeg ta meg en tur i kjelleren og se litt nærmere på det som ligger der. Har lyst på JBL 375 driveren. Men da må jeg selge noe, for å ta meg seg råd til disse
  7. #3207
    Overivrig entusiast ufo's Avatar
    Feb 2016
    Tagget i
    1 Innlegg
    nye budsjettsmodeller iallefall
    https://youtu.be/0DL-PSh-He8?t=517
  8. #3208
    Nov 2004
    Kristiansand
    Tagget i
    0 Innlegg
    Sitat Sitat fra ufo Se Innlegg
    Tusen takk! Dette er akkurat det jeg var ute etter! 50.000 for den største der. Så er vel ikke akkurat budsjetthøyttalere... Virker uhyre spennende disse!
  9. #3209
    Hifi Freak
    Jun 2011
    Tagget i
    0 Innlegg
    Virker spennende. Håper de spiller på dem i Munchen neste år.
  10. #3210
    Hifi-entusiast Naturlyd's Avatar
    Mar 2006
    Tagget i
    1 Innlegg
    Kassene er helt klart det svakeste punktet i denne konstruksjonen. Har aldri vært borte i kasser som er mer uegnet. De både synger med og slipper lyd igjennom. Prøv selv. Spill noe musikk med en fremtredende, dyp mannsstemme. Gjerne nyere Bill Callahan. Det rekker å spille litt over bakgrunnsmusikk lydnivå. Gå bak høyttalerkassa. Du vil nå helt tydelig høre nedre mellomtone komme ut gjennom bakplata på kassa. I tillegg vil du høre at det er en resonant "glasur" som legger seg ovet enkelte frekvenser og gjør at de enten stikker seg ut eller gjør stemmer/instrumenter udefinerte.
    Når du først har identifisert problemene trenger du i hvertfall et par tre gode øl for å orke å høre på selv bakgrunnsmusikk.
    En av grunnene til at det er så lett å høre er pga fordelene til systemet. Høy direktivitet ganske langt ned i frekvens gjør at du lettere hører hva som skjer på side og bak høyttaleren.
    Sitat Sitat fra baldrick Se Innlegg
    Sitat Sitat fra oks81 Se Innlegg
    Kassene er noe tynt skrammel og ikke bra!
    Kassene er bygd i 22mm MDF så vi har nok forskjellig oppfatning av hva som er tynt skrammel
  11. #3211
    Jun 2018
    Sunndalsøra
    Tagget i
    0 Innlegg
    Her er det nye recone kit for et gammelt JBL basselement som dere kanskje kjenner til. Skal i første omgang brukes sammen med JBL LE175 horn eller JBL 075. Dette settet er det nærmeste en kommer orginalen. De som har prøvet ut dette, er veldig fornøyd med resultatet. Skal bli spennende å prøve ut. Kabinettet vil bli rundt 100 liter.
    Navn:      JBL D130 recon kit.jpg
Visninger: 144
Størrelse: 90.3 Kb
    Siste redigert av Motorhome; 10.10.2019 kl. 21:14.
  12. #3212
    Mar 2010
    Tagget i
    0 Innlegg
    Sitat Sitat fra Motorhome Se Innlegg
    Her er det nye recone kit for et gammelt JBL basselement som dere kanskje kjenner til. Skal i første omgang brukes sammen med JBL LE175 horn eller JBL 075. Det settet er det nærmeste en kommer orginalen. De som har prøvet ut dette, er veldig fornøyd med resultatet. Skal bli spennende å prøve ut. Kabinettet vil bli rundt 100 liter.
Visninger: 144
Størrelse: 90.3 Kb
    The D130 was the second low frequency loudspeaker introduced by James B. Lansing Sound after the D101 of 1946. It was personally designed and developed by James Lansing
    Mere info her
  13. #3213
    Jun 2018
    Sunndalsøra
    Tagget i
    0 Innlegg
    Sitat Sitat fra oen Se Innlegg
Visninger: 144
Størrelse: 90.3 Kb
    Mere info her
    Det stemmer det oen Det er et par D 130 16 ohm elementer fra begynneslen av 70 tallet. Mebranen er av papir/papp, og er veldig tynnt. Det ene er forholsvis helt og fint med bare et par sprekker. Det andre elementet er bar i småbiter og helt uttørket. Dette var vel et av det første bass elementet JBL laget og ble brukt mest i toveis systemer? Det gir en spesiell klang, da det er et extended range element med denne ''curved'' hornlignende membranen som skal gi større spredning. Er vel også det mest lettdrevne. Skal bare rekone det ene elementet som er helt defekt først, så får man sammenligne.
    Siste redigert av Motorhome; 07.10.2019 kl. 00:12.
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
