T66 - Første modell ut i GoldenEar Technology sin nye høyttalerserie
Lanseringen av nye T66 vil finne sted under High End messen i München i mai. Antatt pris ved lansering er NOK 83 940,- (NOK 87 540,- for utgaven i rød pianolakk). En romslig rabatt vil bli gitt på alle forhåndsbestillinger som måtte komme inn forut for vår import i juni.
Produsenten skriver følgende:
The T-66 is the first model in GoldenEar’s new T Series. It is not a Triton but honours the Triton Series, sharing a similarly tall, slender profile; built-in DSP-controlled subwoofer amplification; and a driver complement comprising GoldenEar’s High-Velocity Folded Ribbon AMT tweeter, cast-basket mid/bass units, quadratic planar radiators, and a long-throw powered sub-bass section.
Designendringer i forhold til den eksisterende Triton-serien:
  • New smaller-profile metal base with adjustable aluminium feet, ideal for carpets, tiles and wooden flooring
  • Perforated metal grilles offer less restriction to sound from the front firing drive units
  • First bi-wirable GoldenEar design including upgraded binging posts, which ships with high quality AudioQuest biwire jumpers
  • Completely new internal wiring loom to the crossover and mid/tweeters using AudoQuest Zero Tech wiring technology (for reference, the cheapest AQ Zero Tech cable is $/€200 per metre unterminated, so this is a serious cable to use inside a speaker cabinet)
  • Improved crossover design with high quality components, upgraded internal acoustic materials, improved felt around the tweeter, and many other improvements
  • New driver layout, with the side firing bass radiators placed between the 2 active bass drivers, as show in the image below
Et par T66 i rød utførelse er allerede bestilt opp for demo bruk og skal etter planen leveres oss i juni.
T66 var opprinnelig tenkt å erstatte Triton Two+, men yter så bra at den i stedet vil ta plassen til Triton One.R. Siden dette betyr at Triton One.R fases ut, så vil GoldenEar Technology tilby ekstraordinære priser på produktene under i de neste 3 månedene (april, mai & juni) og så lenge lageret rekker:
* Triton Reference til Triton One.R pris
* Triton One.R til Triton Two+ pris
* SuperCenter Reference til 25% rabatt
* SuperSub XXL til 25% rabatt
M.B.S
Fant ikke noe info om denne på produsentens side.
Gjallarhorn Audio
Heggedal, Asker
Lanseringen er, som nevnt over, ikke før i mai. Men her er spesifikasjonene:
Driver Complement:
o One High-Gauss Neodymium High-Velocity Folded Ribbon AMT Tweeter
o Two 4.5" High-Definition Cast-Basket Mid/Bass Drivers
o Two 5" x 9" Long-Throw Quadratic Subwoofers
o Two 8" x 12" Quadratic Planar Infrasonic Radiators
  • Passive Radiator Surface Area: 53.36in2 (344.3cm2)
  • Efficiency: 91dB 1W/1M @ 4Ω (2.83V/1M)
  • Frequency Response: 29Hz–25kHz typical (-6dB on axis @ 29Hz, anechoic bass response)
  • Nominal Impedance: 4Ω
  • Recommended Amplification: 20–500Wpc
  • Built-In Subwoofer Power Amplification: 1000W peak/500W RMS, DSP-Controlled
Dimensions:
o Tower: 7.5" (19.1cm) W x 14.75" (37.6cm) D x 48.8" (124.1cm) H (with base, no spikes)
o Base: 11.8" (30cm) W x 17" (43.2cm) D • Weight: 60lbs (27.2kg)
Gjallarhorn Audio
Gjallarhorn Audio sine annonser
Besøk oss på Oslo HiFi Show nå i helgen
Vi har intet mindre enn 6 Norgeslanseringer under Oslo HiFi Show nå i helgen. Du finner oss på rom 106 og 108 i første etasje. Under kan du se hvilke produkter det er Norgespremiere på. Velkommen...
Gjallarhorn lanserer franske B.audio i Norge
  • 5
B.audio er et forholdsvis nystartet firma, men de har i løpet av kort tid blitt anerkjent for sitt gode design og høye lydkvalitet. Firmaet ble grunnlagt i 2016 av brødrene Cédric og Sébastien...
Sveitsiske Stenheim endelig i Norge
  • 10
Varemerket Stenheim ble etablert i 2010 av fem elektronikkingeniører som tidligere hadde jobbet i det sveitsiske high-end firmaet Goldmund. Deres første høyttaler, Alumine, ble lansert i 2011...
Gjallarhorn showroom holder stengt i romjulen
  • 6
Vi lar julefreden senke seg og holder vårt showroom stengt i romjulen. Men vår nettbutikk vil være betjent og det vil fremdeles være mulig å hente varer på vår adresse ved kjøp eller hjemlån i...
Juletilbud på Harbeth (-25%)
Det blir juletilbud på Harbeth ut desember for å få ned vår lagerbeholdning. Alt av modeller, bortsett fra toppmodellen, er på lager i de fleste finisher. Merk at tilbudet om 25% rabatt på...
Juletilbud på SPEC (-25%)
Vi kjører juletilbud på SPEC i hele desember ved å tilby 25% rabatt på alle produktene som befinner seg på lager. SPEC sine integrerte forsterkere er unike klasse D forsterkere med lav effekt...
