Ø Audio opplever sterk vekst globalt med nye distributører og bred pressedekning i viktige markeder. I 2025 fortsetter reisen med store messer som AXPONA (USA), Munich High End Show, og mye mer spennende på agendaen!
"Ø Audio began in 2010 with an idea that translated into an innovative loudspeaker called Icon, a two-way design with a horn-loaded compression-driver tweeter above a 12-inch woofer. Flash-forward to 2025 and Ø Audio now has three loudspeakers: the newest version of the Icon, called Icon 12; the flagship Verdande; and an entry-level model called Frigg 02. The Verdande and Icon 12 are, like the original Icon, are two-way designs, each with a horn-loaded tweeter and a large woofer. The Frigg 02 is a more conventional-looking three-way design, but with a sonic signature that is said to match its large, more expensive series mates. In this video, company cofounders Sveinung Mala and Jonathan Cook describe each model and what the sonic goals for all three speakers are. You will also learn what Ø Audio actually means."
- Sound Stage
- Sound Stage
3.9 MB Visninger: 34.690
