More power: Asgard 3 provides 3.5X the power output of previous Asgards.
Higher performance: Asgard 3 is also far quieter, and has less distortion than previous Asgards.
Modular, configurable, upgradable: Asgard 3 accepts all the same modules as Jotunheim and Lyr 3, so you can add an internal DAC or phono stage.
Continuity, not Class A: Asgard 3 uses our unique Continuity output stage to extend the benefits of Class A operation. It’s still biased heavily into Class A, with over 500mW of Class A operation into 32 ohms.
Bigger power supply: Asgard 3 now has a 48VA transformer, 50% larger than any previous Asgard, plus over 20,000uF of filter capacitance and low-noise series regulation of stacked power supply rails, plus separate supplies just for the oversight and the cards.
More convenience: Now you can select the input and gain from the front of the amplifier. Previous Asgards didn’t even have selectable input, and gain was on the back.
Lower cost: Asgard 3 costs $50 less than previous Asgards, despite all these years of depreciating dollars and all the new features.
Destiny
