Nyhet! Audia Flight FL Cd Three S
Audia Flight nye cd spiller FL CD Three S er klar for markedet! Dette er cd spilleren for de som ønsker en analog og varmtlydene spiller.
Pris kommer.
Ta kontakt om du skulle ha spørsmål ved noe!
JWK Audio/Sound of heaven
Tlf:+47 464 29 861
E-mail: kontakt@soundofheaven.as
Hjemmeside: www.soundofheaven.as
FL CD Three S cd player
Audia Flight introduce the FL CD Three S, a brand new development cd player for the lovers of really good music.
Starting with its elegant Italian exterior, the FL CD Three S has solidly built casework with a thick aluminum (10 mm) front panel.
In your hand you'll also find a compact, ergonomic remote control hewn from solid aluminium. A large, blue OLED display will keep your eyes informed about all info you need.
The new unit is making use of a CD-Drive which is optimized for single speed playback and not just another computer drive. Also it uses two AKM4493EQ 32-Bit Dacs with “velvet sound” technology (one per channel).
In addition to that Audia Flight is offering the choice of no less than six Digital Filters and one of them is a modernized version of the legendary Audia Flight filter in the original Flight CD1.
Audia Flight is using two completely separate toroidal transformers for the analog (58VA) and digital (36VA) circuits.
Unlike most manufacturers the analog output section of the DACs is fed from the analog power supply as well.
The output section is, in Audia Flight style, A Class discrete current feedback technology and naturally the unit is fully balanced, so balanced and unbalanced analog output are available. It is also available a digital output.
As a special option an input card with five digital inputs (2x Opto, 1x AES/EBU, 1x Coax, 1x USB) is available and can easily be retrofitted at a later point in time.
The USB input allows for 32/384 PCM and DSD 512 and thus makes the unit future proof as a standalone DAC. All digital inputs are insulated to prevent any noise from the digital sources.
All digital inputs are optionally upsampled up to 32bit 768KHz.
100% Made in Italy!
Technical Data
Frequency response: 0.5 Hz ˜ 20 KHz ± 0.1dB
Upsampling (only for digital inputs): 32 bits, 768 KHz
Dynamic Range: 126 dB
THD: + noise: >0,01%
Noise: >- 113 dB
Balanced and Unbalanced outputs
Maximum output voltage: 2.5 Vrms
Output impedance: 200 Ohm
Digital Output: PCM S/PDIF
Stand-by power consumption: less than 0,5 W
Operation Power consumption: 30 W
Main voltage AC (50-60 Hz): 100, 110-115, 220-230, 240 V
Dimensions: 450x110x430 mm (WxHxD)
Weight: 10 Kg
Shipping dimensions: 550x250x580 mm (WxHxD)
Shipping weight: 15 Kg
Optional Digital Board:
Inputs:
• 1 XLR AES/EBU
• 1 coaxial SPDIF
• 2 opticals
• 1 asynchronous USB
All inputs are insulated.
The USB input can accept files 32 bit 384KHz and DSD512
sound of heaven
sound of heaven sine annonser
Atohm GT2-HD - Testet i Stereopluss
  • 2
Atohm GT2-HD - Testet i Stereopluss! 5 av 5 stjerner! Par utdrag fra testen: - Det er også veldig morsomt å høre høyttalere som slipper lyden så lekende lett som GT2-HD. Her hører man ikke mye...
Xavian Perla Esclusiva
  • 2
“Nature in everything is enough for everything” Hippocrates Xavian Perla Esclusiva har siden lanseringen blitt en umiddelbar suksess og kritikerrost over hele verden. Til prisen så setter på...
XAVIAN - La vita in musica
  • 2
Sound of Heaven har blitt importør og har gleden av kunne gjenintrodusere Xavian høyttalere på det Norske markedet. Xavian sin grunnlegger Roberto Barletta vokste opp i en familie av musikere. Så...
Nytt brand hos Sound of Heaven
  • 12
Hva kan dette være, mon tro :) JWK Audio/Sound of heaven Tlf:+47 464 29 861 E-mail: kontakt@soundofheaven.as Hjemmeside: www.soundofheaven.as
Nye utmerkelser til Audia Flight FLS10
Audia Flight med sin eminente FLS10 som blant annet har blitt kåret til årets integrerte forsterker i Polske High Fidelity 2018. Fortsetter sin seiersgang nå i år med å bli kåret til årets...
Nyhet fra Audia Flight
Spennende nyhet fra Auida Flight, FLS9. Dette er en ny integrert forsterker fra deres FLS serie til en rimeligere pris enn deres kritikerroste FLS10. Prisen på Audia Flight`s nye modell er...
