Horten Messen Norges Premiere på Audia Flight FLS 20 SACD spiller med streamer modul
Premiere på Audia Flight FLS 20 SACD spiller med streamer modul.
world-class disc player, but also a versatile high-end digital hub.
FLS20 was engineered with ultra-short signal paths and a minimalist, highly optimized circuit design. After countless hours of listening tests and detailed technical refinement, the disc drive system was designed entirely from scratch. This proprietary mechanism virtually eliminates all forms of internal and external vibration—one of the most critical challenges in high-performance disc playback. Vibrations are the greatest enemy of disc players, and true sonic excellence is only possible when such interference is fully controlled. As a result, the
FLS20 reads disc data with impeccable precision and delivers a pure, uncolored signal to its advanced audio circuitry.
The chassis of the FLS20 is solidly built, with a thick brushed aluminum front panel ensuring both durability and aesthetic elegance. At the heart of its digital-to-analog conversion are two Sabre ES9038PRO 32-bit DACs, operated in mono mode (one per channel), paired with an ultra-low-noise Crystek CCHD-950 clock for extraordinary timing accuracy. The digital section is powered by 10 ultra-low-noise power supplies, ensuring absolute signal integrity.
True to Audia Flight tradition, the output stage is a fully balanced, Class A, discrete current-feedback design, offering both balanced (XLR) and unbalanced (RCA) analog outputs. This stage is powered by four discrete, low-noise voltage regulators. The power supply architecture includes three separate toroidal transformers—80VA dedicated to the analog section, 85VA to the digital circuits, and a 15VA transformer for logic control—ensuring clean, isolated power delivery across all functions.
Connectivity is equally impressive, with four digital inputs (Toslink, AES/EBU, S/PDIF, USB) and four digital outputs (Toslink, AES/EBU, S/PDIF, and I²S), making the FLS20 not just a world-class disc player, but also a versatile high-end digital hub.
Technical data
Frequency response:
2 Hz – 50 KHz ± 0.5 dB (SACD)
2 Hz – 20 KHz ± 0.5 dB (CD)
S/N ratio: 110 dB
THD: 0.002%
Analogue outputs: balanced and unbalanced Maximum output voltage: 2.5 Vrms Output impedance: 240 Ohm Digital inputs: 4 (Toslink, AES/EBU, S/PDIF, USB) Digital outputs: 4 (Toslink, AES/EBU, S/PDIF, I2S) Stand-by power consumption: less than 1 W Power consumption: 150 W Main voltage AC (50-60 Hz): 100, 110-115, 220-230, 240 V
Dimensions: 450 x 134 x 364 mm (WxHxD)
Weight: 17 Kg
Shipping dimensions: 570 x 260 x 560 mm (WxHxD) Shipping weight: 22 Kg Available finish: silver or black
Audio Aktøren
Audio Aktøren sine annonser
Husk Butikken i Storgata 22 er en del av messen. Her selges det også vinyl 🙂
Her er bilder fra DIY på messa Horten. Seas aktiv prototype. Bygget av Hans Erik Lian
  • 13
Da er vi i gang med unboxing av Alsyvox BOTTICELLI
SEAS kommer til Horten messa den 3 til 4 oktober. Dette bør alle DIY entusiaster få med seg
  • 5
SEAS Fabrikker i Moss har i mer enn 75 år utviklet og produsert høyttalerelementer i absolutt verdensklasse. Vi er ca 30 dedikerte medarbeidere som har som mål å gi deg lydopplevelsen du mister...
Da er det bare å glede seg til neste helg
Sigberg Audio stiller da ut Sigberg Audio Saranna
  • 2
Sigberg Audio stiller da ut Sigberg Audio Saranna, som er en fullfrekvent, gulvstående aktiv høyttaler med 3x8". Pris: 270 000kr/par. Prisen inkluderer levering og personlig oppsett og tilpasning...
