Hør Esoteric Grandioso T1 under After München 9. og 10. juni
Esoteric Grandioso T1 er et mesterverk av en platespiller. Med sin magnetiske kontaktløse drift, Esoteric MagneDrive system er dette en av de mest avanserte spillerne på markedet.
Under arrangementet After München hos oss 9. og 10. juni kan du se og høre den.
Key Features
AFTER MÜNCHEN hos Mala Audio!
Arrangement her: Asker, Akershus av Mala Audio fredag, juni 9 2023
fb.me
Key Features
- Esoteric’s patented contact-free drive system “Esoteric MagneDrive System”
- Magne-Float platter greatly reduces spindle bearing friction by reducing platter’s effective mass from 19kg down to approx. 4kg.
- Consists of 3 separated units: main unit, motor unit, and power supply unit.
- High quality VCXO motor driver ensures precise platter rotation.
- 10MHz Clock Sync capability with the Grandioso G1X Master Clock.
- Inverted bearing system supports smooth rotation of the platter.
- The Micrometer knob on the front panel provides fine-tuning capability of sonic characteristics, by adjusting the strength of magnetic force being applied from the magnetic driver to the platter.
- Triple layer chassis made of Aluminum and wood, effectively controls vibration.
- The mid-chassis is applied with beautiful high gross piano lacquer.
- The isolation feet have a special damping mechanism that eliminates external vibration.
- Two speed control (33/45 rpm), adjustable with 0.1% order.
- The T1 is offered with TA-9D dynamic balance tonearm, or without tonearm configuration.
- Optional arm-board allows the T1 accommodates up to 3 tonearms.
