Fiio launched their new flagship Fiio M15 music player. It is an amazing DAP in 2019.Becasue it is comes with AKM4499 DAC chip, the chip is known for its superior performance and this chip is also the most used chip in other brands' flagship desktop DAC.
Features:
Flagship DAC Chip AK4499*2
Performance Leading SoC Exynos7872
Qualcomm Flagship Bluetooth Chip CSR8675
Two Femtosecond Crystal Oscillators from NDK, Japan
Independent XMOS XUF208 Control Chip
768kHz /32bit, Native DSD512
Third Generation FPGA Technology
Professional ADC Volume Adjustment Mode
Ten Low-noise Operational Amplifiers
Fifth Generation Classical Column Modeling
Corning Gorilla Glass
18:9/720P/5.15 Inch Display Screen
2.5mm/3.5mm/4.4mm Headphone Jack
Five Physical Buttons with Customizable Functions
CNC Machined Aluminium-Magnesium Alloy Chassis
Solid North American Black Walnut Wooden Enclosure
Independent "HOLD" Switch, PCB Coated with Graphite and Thermally Conductive Silicon Grease
Innovative multifunctional button
Customized open Android system
Fully Decode (8x) the Original MQA Files
All to DSD 2nd Gen
One-click Standby Mode
18W Dual Quick Charging
FiiO Original Music APP
Android / Pure Music / USB DAC / Bluetooth Receiver
Gateway of Music (FiiO Link, DLNA, AirPlay, WiFi Song Transfer)
The display is a 5.15-inch 1440 x 720 (HD) display that looks beautiful from everywhere. The external connection terminal adopts USB Type-C and supports bidirectional communication. Of course it has a microSD slot and supports mounting up to 2TB .
The new generation FPGA chip processes Actel pre-decoded signals to ensure accurate signals and correct timing errors and jitter. Comes with a pair of Femtosecond Crystal Oscillators clock from NDK, Japan. The most important is that the product uses two AK4499 Dual DAC chips, AKM's exclusive new LSI audio processing system that helps specifications such as THD + N and SNR to extremely low, the lowest on the Current player model. This product also marks the close cooperation between AKM and FiiO, from development to completion of the product. The internal circuit of FiiO M15 is designed True-Balanced with an independent 4-channel amplifier system. Gold plated 8-layer PCB.
Now you can order from Hifigo online store priced at $1459.99, if you have any problem please contact support@hifigo.com
Hifigo FB official page https://www.facebook.com/HiFiGoAudio/
Features:
All to DSD 2nd Gen
900.3 KB Visninger: 856
