Chromecast med eller uten dac?
666
Har det noe for seg å benytte en dac til Chromecast audio og Spotify?
Vil gjerne høre fra de som har prøvd med og uten.
Sitter vel en dac chip i Chromecasten.
Jeg spiller mest vinyl men av og til Spotify.
Lasse
Handsoer
Sortland
Lasse
Ja - det vil jeg tro...
Har prøvd Chromecast Audio direkte i forsterker og det låter huggorm.
Så dårlig at jeg ikke har samvittighet til å selge den for en hundrings :rolleyes:
Om det blir mye bedre via dac vet jeg ikke.
(men om du har en dac er det vel bare å gå for kablet løsning?)
mvh hans
Balle Clorin
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-chromecast-audio-digital-output.4544/
Conclusions
There are a few here:
1. The CAST audio functionality of Google Chrome is horrid. There is no excuse for it to be butchering even simple 16-bit signals as it did. While audibly it is not as dire as it looks, I still would avoid it if you can.
2. Roon's implementation of Chromecast streaming is superb. It is bit accurate up to 24 bits and 48 kHz that I tested. Congratulations to Roon for job well done. I assume they received support from Google to implement it as the protocol otherwise is not open to the public.
3. The Chromecast output has more jitter than an audiophile/instrument grade Toslink output. This is evident when used with low quality DACs like Schiit Modi 2 Uber.
4. Using a well-designed Dac like the Topping D50, there is no difference at all between Toslink from Chromecast or higher fidelity sources. All the jitter is filtered out resulting in the performance of the DAC itself being the limit.
#4 is a great news here. It means that if you have a good DAC and use Roon, you can turn your DAC into a streamer/renderer using the Chromecast Audio. For just $35, that is a superb addition. As such, the combination of Roon and Chromecase audio is highly recommended!
EDIT: bit-perfect playback is also supported in Android apps like Hi-Fi Cast. See: https://audiosciencereview.com/foru...omecast-audio-digital-output.4544/post-102185. So you are not just limited to Roon.
https://allaboutchromecast.com/chromecast-audio-guides/what-are-the-3-compatible-audio-cables-for-chromecast-audio-and-why-it-matters/
Takk Clorin, tror en bedre streamer er enkleste løsningen.
Hva synes du selv?
Lasse
lovemusikk
Lasse
Mye bedre med dac.
Chromecast har mye støy og jitter i følge tester
666
Så hos deg ble det en klar forbedring?
