Vet ikke om denne har vært nevnt her før (søkte, men fant ei)....Turntable-PS-100-in-pianoblack fra...tyske Block, med mottoet "Audiopihle Produkte für Jedermann". Har ingen spørsmål nå, bare bringer videre det jeg finner....altså denne:
til 1.299 Euro (nkr 9599,09 med dagens kurs, eks +/- moms)
Teksten under videoen oppsummerer slik:
The PS-100 is equipped with a solid external motor weighing 2kg, with an adjustable 33/45rpm switch and spiked supporting feet.
The chassis is made of a highly polished black MDF, with perfectly made aluminium profiles and also sits on spiked, adjustable supporting feet.
An acrylic turntable with a board weight, a felt slipmat, a very light (12 gr.) uncropped and with 68 grams - counter weighted pick up complete this device and make it comparable with other devices costing 2000.00? or more.
The Pick Up can be adjusted whilst the device is in use, thus making it easier to adjust to different vinyl thicknesses.
Even an untrained person will have no difficulty in setting up MM- or MC Systems with the accompanying record setting template.
"Record-Player PS-100
- Speed: 33.33/45 RPM +/-0.05%
- Crosstalk: -73db
- Power consumption: 14W
- Powersupply: DC 15V, 1.6A
- Dimensions (B/T/H): 550/407/175mm
- Gewicht: 15 kg
An acrylic turntable with a board weight, a felt slipmat, a very light (12 gr.) uncropped and with 68 grams - counter weighted pick up complete this device and make it comparable with other devices costing 2000.00? or more. The Pick Up can be adjusted whilst the device is in use, thus making it easier to adjust to different vinyl thicknesses. Even an untrained person will have no difficulty in setting up MM- or MC Systems with the accompanying record setting template"
